Loss of power
Old Jan 6, 2013
01civichx's Avatar
01civichx is an unknown quantity at this point
Loss of power
hi guys. i have a 2001 honda civic hx i noticed while driving my car that it was losing power. then on new years my car turned on but when i put it in gear it turned off. whenever it does stay on while its in first gear the car wont go over 2000 rpm. it would struggle to turn on so i changed the starter. when idleing the engine would shake. i changed the cooling fan switch and that stopped the shaking but it still has no power. my mechanic has checked the timing belt, the valve adjustments, he did a compression test, spark plugs, igntion coils and everything is good. i cleaned the idle air control valve and the throttle body. i was thinking maybe it would be the catalytic converter so i emptied it out and the car still has no power. i dont know what else it could be. if you guys could help me out i would really appreciate it. thanks in advanced.
Old Jan 12, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: Loss of power
Sounds like your civic is running in limp mode.. Have you checked/replaced the distributor recently?
Old Jan 12, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: Loss of power
Umm his car has ignition coils. No distributor.
Old Jan 13, 2013
01civichx's Avatar
Re: Loss of power
i found out what the problem was. im guessing before i emptied out catalytic converter it broke and clogged up the exhaust pipe.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
1khilari
Jul 9, 2015 08:12 PM
