2008 Honda Civic Hybrid - Oil pan crack
Hi all,
I just bought a used 2008 Honda Civic Hybrid and the Precision tune Mechanic showed me a crack on the oil pan today, starting from the drain plug thread extending to 2-3 inches. When he tried to tighten the screw the crack gets widen. Now he says only way is to change the oil pan for $900
($450 +labor $450)
I never knew about this before when I bought the car 2 weeks back from a private party ,Is this a cost normal or shall I try another mechanic or should this be done only with Honda mechanic or Is there any alternate for fixing this crack temporarily ?
Please help.
($450 +labor $450)I never knew about this before when I bought the car 2 weeks back from a private party ,Is this a cost normal or shall I try another mechanic or should this be done only with Honda mechanic or Is there any alternate for fixing this crack temporarily ?
Please help.
Re: 2008 Honda Civic Hybrid - Oil pan crack
The oil changer showed you the problem? Was the problem obvious?
What are the chances that the oil changer caused the problem?
How do you think that would be proven?
Do you know what happens when all the oil leaks out of the engine?
No, it is not normal for an oil pan to crack.
I have seen it happen though, but explaining how it was caused would be pointless.
I have no way to evaluate the cause of your problem other than to say most likely a human caused it.
If the threads for the drainplug were stripped, that might be fixable.
Cracked pan must be replaced.
It seems you likely bought someone elses problems. Suck it up and fix it before the engine is ruined.
Suggest second opinions and estimates though.
Call the dealer and ask for an estimate on it too.
Labor charge sounds right.
Parts price may be a bit high if in the USA.
But hey, we have to eat too.
Add a little for the gasket, sealant and oil and some misc.
See this link, part #4 is the oil pan: http://www.hondaautomotiveparts.com/...LOCK+-+OIL+PAN
I did a pre-car inspection and the crack was not brought to my notice then, but one thing the mechanic who did the pre-car inspection told me is "the oil was 1q quart low and he filled it up" and I never probed it why it was low
The oil changer showed you the problem? Was the problem obvious? - Yes
What are the chances that the oil changer caused the problem? May be but what are the chances of oil changer causing it ? what should he have done to causes a oil pan crack ?
I have no way to evaluate the cause of your problem other than to say most likely a human caused it. What do y mean by a human caused it ? You mean the car was not taken car properly by the previous owner or mechanic caused it ?
I will take the quote from the dealer tomorrow and also take a second opinion.
Thanks for ur help
? The oil changer showed you the problem? Was the problem obvious? - Yes
Thanks for ur help
Someone with real mechanical talent normally won't spend their life as a "lubie". They will move on to a real shop that does more in-depth work, and hopefully gain some of that "feel" and experience.
Rookies are far more likely to strip out and damage drainplugs and pans. Next step might be an oversize plug to "bandaid" the boogered threads. This may stress and spread the hole, causing the cast aluminum to crack.
I have also seen cracked casting caused by an overused sealing washer on a transmission drainplug, coupled with overtightening.
The vast majority of stripped pan threads we see in this shop here can be directly attributed to rookies and JizzyLube type places. Yes, dealers employ rookies too.
The boss hates to pay my wages to do nothing but change oil.
I can't tell you that your latest oil changer caused the damage, but I can assure you that somewhere along the cars life, that drainplug and pan have suffered abuse.
Maybe you just found out WHY the last owner got rid of it.
Did that make more sense?
Yeah I do agree that this could have been a rookie mechanic's job who can cause crack by meddling with the drain plug , but (as I said before) when I did the pre-inspection I saw the oil level reduced, this makes me suspect more on the previous owner.
I just want to know , what others things makes a oil pan crack , other than oil change mechanic's fault. This is a clean -title car with 60k miles millage and single owner. What would my previous owner done to the car to cause a crack ?
I also gave my car to Honda dealer to fix it , they are charging me 300$ for Oil pan and 750$ for the labor(seems like a huge work) and parts are yet be shipped.
HINT: It's not his car now.
Curb or jack or accident damage wouldn't start at the drainplug hole.
What would my previous owner done to the car to cause a crack?
750$ for the labor
You in a big Metro area dealer?
What is the labor rate there per hour?
Ask those guys what they think caused the damage. They can see it. I can't.
A crack at a hole like described happens from overtorque. I agree with the human cause theory, but good luck proving it.
A dealer will only replace the pan. It can be welded, but it is slightly difficult because of oil in the pores of the aluminum. I have had this sort of work done before.
Good luck in a reasonable resolution to the problem.
-SP
-SP
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
