HELP no spark 2002 civic
Old Nov 14, 2012
yanksrule1121's Avatar
yanksrule1121 is an unknown quantity at this point
okay so my car was over heating due to a blown head gasket i got it replaced an had the head shaved down me an my dad put it back together an now it wont start it did before we did the gasket i made sure the timing was right we changed the crank an cam sensors thinking that would be it but the engine will turn but still no spark an it dosnt seem as if the fuel pump is pumping gas either someone helllp its been 3 weeks i havnt gotten to drive the damn thing haha thanks-matt
civic 2002 ex 1.7 automatic
Old Nov 14, 2012
Kennykid2002's Avatar
Kenny the Ricer
Re: HELP no spark 2002 civic
Did you prime the fuel pump before attempting to start it?
It sounds to me you cranked it until it wouldn't crank no more, and that you've flooded the engine.
Old Nov 15, 2012
04 Honda Civic's Avatar
How do you know its not getting spark? What did you do to test that?
How do you know its not getting fuel? What did you do to test that?
Old Nov 15, 2012
i took out a spark plug an touched it to metal when i turned the engine over no spark an put my ear to the gas cap to try an hear if it was sucking fuel an it didnt seem to be
Old Nov 15, 2012
Start by checking fuses, both under the dash and under the hood.
A quick way to check for spark is to leave the plug in the cylinder, take off the coil, and stick a test light in there see if it lights when you crank it over. (Ground it first)
Not really sure what you mean when you say you pulled the spark plug out, it was connected to the coil when you did this?
Old Nov 16, 2012
mikey1's Avatar
im assuming he removed the spark plug and plugged it into the end of the coil then watched it while somebody cranked the engine,
not really the best way to do things unless you secure a good ground wire from the spark plug to the engine block,
simply resting the spark plug against the engine will not work (well)
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
jonavin
73
Oct 4, 2004 07:18 PM
CapYoda
Nov 11, 2001 05:17 PM
