Head Gasket problems
Old Oct 2, 2012
lynnh's Avatar
lynnh is an unknown quantity at this point
Has anyone had head gasket problems in 2004 Honda Civics due to possible "hot spots"? Trying to find out if this is an issue with certain year models.
Old Oct 2, 2012
mikey1's Avatar
Re: Head Gasket problems
what do u mean by a hot spot?
what is happening that makes you think you have a problem?
Old Oct 2, 2012
lynnh's Avatar
I had to have the HG replaced. Coolant was filling up my overflow tank & tests confirmed it had to be replaced. I have read on other sites that a possible cause is that "hot spots" develop in the cylinder head between the center cylinders and causes "thermal crush". Apparently it was common in older Honda Civics with 1.3 & 1.5L engines.
Old Oct 2, 2012
mikey1's Avatar
generally speaking when a head gasket fails, the coolant level will drop, not increase, that is very odd
Old Oct 2, 2012
lynnh's Avatar
The coolant level did drop & went into the overflow tank. The HG definitely went bad (I have a very good, honest mechanic) & I am trying to find out if there is possibly some faulty gaskets on some Honda Civics mfg'd during a specific time or if it is an issue with certain models/years of Hondas.
Old Oct 2, 2012
mikey1's Avatar
if the coolant level drops, the amount in the overflow tank would go down, not up
Old Oct 2, 2012
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Head gaskets can fail in different ways. In the 7th gen Civic the most common failure allows combustion gases into the cooling system. This displaces coolant with gases and forces the coolant into the overflow tank.
Old Oct 3, 2012
bryan.0831's Avatar
bryan.0831 is an unknown quantity at this point
And spits it out from the overflow tank cap like hot fire!!
I own a 2005 and It happened to me twice already... I am a very lucky 7th gen owner.
Old Oct 9, 2012
Largen's Avatar
Largen is an unknown quantity at this point
Just happened to mine like... two months ago. the bugger was not giving me ANY signs of what it was besides lost coolant, then one day it pressurized my coolant system, took the stupid thing long enough......
As for the "hot spots" if that is the cause (could be MANY more things) let your car idle for a bit before shutdown, and run it easy for a few minutes if you have been bagging on it before shutdown to help normalize the tempurature of the engine. should help prevent pre-mature Failure of the Gasket in the future, and thats a Should***
Old Jun 13, 2020
hray's Avatar
hray is an unknown quantity at this point
The deck get warped on the block,, bad engine design,, take something that is flat and is as long and wide as the block glue sandpaper to it,, ,,, you can use a black felt marker on the deck,, then sand and you will see all the low spots,, resurface the head and the deck should be really smooth,, check dowels pins aren't bottoming out,,
Old Jun 13, 2020
hray's Avatar
Block beck is warped,,, flat plat as long and wide as the cyl and sandpaper 200grit finish with 400grit & thenbuffing wheel,,, glue the sandpaper spray adhesive,,, black sharpie the deck,, you can see all the low spots,,,,
zaboomafoozarg
May 30, 2015 09:21 AM
HondaHomer
May 14, 2015 12:24 PM
hokiedad4
May 3, 2015 10:06 PM
hokiedad4
Apr 30, 2015 07:18 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
