03 Civic Hybrid lowering????
Old Aug 22, 2012
Besimple1's Avatar
Besimple1 is an unknown quantity at this point
Just wondering if anyone has done this and what is the best way to do it? Obviously, I'm not racing it or ever driving aggressively. I have read that the spring rate is different in the rear than other 03 civics to make up for the added weight from the tank of a battery it has. I'm pretty sure no one has a specific lowering kit for Hybrids... So am I right in assuming, I should do adjustable full coil overs and set them accordingly so my car looks and handles good. I have read through the other threads and haven't found exacts about 03 Hybrids. Also, a camber kit, and what else do I need so I can save my tires? It's got 170,000 on it so I need new shocks anyways. Thanks
Old Aug 22, 2012
krudmuphin's Avatar
Re: 03 Civic Hybrid lowering????
I've never seen a lowered Hybrid, but that would be so awesome!
Go for it!
Old Aug 22, 2012
krudmuphin's Avatar
Go for it!
Old Aug 23, 2012
gonna need adjustable coilovers for sure. just dont cheap out on the brand/quality. yes there is noticably more weight in the rear so you need stiffer shocks. dont go much lower than 1-1.5 inch all around.
Old Aug 23, 2012
Besimple1's Avatar
How do I get stiffer shocks? Do I have to special order the coilover? Or order front (normal) and rears (stiffer) separately? I understand you can order different spring rates with just springs, but do coilovers come with the same rated springs? And what do I need to measure so I get the right ones. I read something about 14mm or 16mm? Thanks
Old Aug 23, 2012
yeah i think for 03 it came with different bolt sizes. you would have to check with the company if they work on hybrids. or at least try and remove some weight from the trunk like the spare tire and tools. but full coilovers should already have the shocks rated for the amount of lowering they do.
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
inarschenk
South
Apr 18, 2015 04:29 PM
dooner24
Apr 14, 2015 07:51 PM
