Alternator and Battery problem
Old Jul 28, 2012
GERRYC's Avatar
GERRYC is an unknown quantity at this point
I own a 05 Civic and replaced the battery after my car wouldn't start and found out the battery was dry. With a brand new charged battery I am reading 16.5 volts across the battery terminals with the car running. My friend says that my alternator is putting out too much voltage and this is what cooked my battery. Should my alternator be replaced?
Old Jul 28, 2012
Re: Alternator and Battery problem
he is right, faulty alternator killed the first battery and will kill the new one, along with your car's electrical parts if you wait too long.
Old Jul 29, 2012
palsana's Avatar
palsana is an unknown quantity at this point
OP, did you change the battery cables with new ones.When i was cranking up the battery, it wouldnt start, i took it to Autozone and put it to test & they told me something was eating up the battery!!!.. Battery was losing power & had only 29% charge left. Autozone swapped my battery and have new one.
Gonna put new battery cables & also check on alternator.
Old Jul 29, 2012
GERRYC's Avatar
Would replacing the voltage regulator in the alternator probably solve this problem?
Old Jul 29, 2012
its usually cheaper to buy a new alt than to fix the old one, but yes more than likely the regulator went bad.
Old Jul 30, 2012
GERRYC's Avatar
Thanks for your help Gearbox.
roverben
Jan 21, 2019 05:16 PM
MiniMi
May 27, 2015 01:57 PM
smmahan
Apr 15, 2015 08:17 PM
OPGForce
Feb 7, 2002 09:43 AM
2k2civic
Dec 6, 2001 09:41 AM
