Electrical issue
Old Aug 1, 2012
iridehonda's Avatar
iridehonda is an unknown quantity at this point
Electrical issue
The other day I was reconnecting a loose wire on my headunit's harness. As I went to put headunit back in I heard a pop. I turn the car on, no power to the headunit. Then I realize that my doors will only lock/unlock with the key turned over. I also noticed my dash will not light up when the key is not in the ignition, even if the lights are on. The orange illumination wire is disconnected and has been capped since I put the HU in.
I checked a couple fuses that I thought could be the culprit but everything looked fine and swapping in other fuses in their place did nothing. Does anyone know what happened? Did I just blow a fuse? Did I fry something? Any hidden fuses I should check?
Thanks for the replies.
Old Aug 1, 2012
sl33pyriceboi's Avatar
Re: Electrical issue
Did you check both fuse boxes.?
Old Aug 1, 2012
iridehonda's Avatar
I did but the fuses aren't labeled very well and I did not go through them all. Any Idea on what fuse it could be, specifically? And I'm assuming it does sound like a fuse problem to you?
Old Aug 1, 2012
CraigW's Avatar
Fuse named "back up" in under-hood box. (constant 12 volt items)
Old Aug 1, 2012
iridehonda's Avatar
That's exactly what it was. Thank you very much.
Old Aug 3, 2012
CraigW's Avatar
Old Aug 3, 2012
palsana's Avatar
palsana is an unknown quantity at this point
Both Fuse Boxes? where is the second one on 2003 civic. Behind GloveBox.
Does it also have the #6 fuse for the ECM/PCM re-learn
Old Aug 3, 2012
you have one under the steering wheel and one in your engine bay (near the passenger side front wheel)
Old Aug 3, 2012
palsana's Avatar
Thats under the hood as lots of them here call it right? Or is it under the dash(inside the car) on passenger side.(by the glovebox).
So there is one under the steering wheel inside the car?
Old Aug 3, 2012
palsana's Avatar
sorry but i have a DREADFUL HATRED for MACHINES. I JUST DONT EVER GET THEM
Old Aug 3, 2012
Under the hood.
Old Aug 3, 2012
palsana's Avatar
thanx
Old Aug 4, 2012
No problem
h4ldol
Jun 3, 2015 03:26 PM
juror
May 26, 2015 06:35 PM
WLakers
May 4, 2015 06:23 PM
mohawkboom
32
Oct 9, 2006 02:49 PM
mohawkboom
50
Apr 21, 2002 06:12 PM
