97 civic 2-door power window issue
Old Jul 21, 2012
ekcivicguy's Avatar
ekcivicguy is an unknown quantity at this point
hello fellow honda lovers im in need of advice/help its summer here in florida and my driver side window wont workn in my 1997 civic 2-door. I had replaced my window switch also checked my fuses along with replacing with window motor and regulator and it still wont go up or down. im now stressed out due to the fact i have my wife and my 4 year old son use the car in the day and i only work nites so its not that hard to deal with but would be great to get this issue figured out alos working on my a/c since my compressor blew so you know its a freakin oven. beofre it broke we had a hard time getting it to work up and down we had to close and open the door and slam it hard to get it to wanna go up and down and now it wont matter cus it wont work. well please please help a family man out here in this sunny hot azz state of fla. Thanks
Old Jul 21, 2012
rollondad's Avatar
rollondad is an unknown quantity at this point
Re: 97 civic 2-door power window issue
I can't say I know a lot about this kind of thing, but here comes a little input. Your description says initially it was tough to get us and slamming door helped, so that sounds like motor, regulator (which I hear is common) or a loose or broken wire. I think you need to test the wire coming to the motor and or regulator to see if there is power there. Whether there is or isn't will point you in which direction of the circuit to look for the problem. If there's power at the connection then you want to test the motor and regulator separate from the circuit. If there's not, backtrack to the switch to see if there's power out of the switch. If not then test back to the fuse block to see if you've got power there. Breaking the circuit into smaller pieces youll be able to pinpoint what works and what doesnt. Remember just because you put in a new part doesn't mean it couldn't be defective. Good luck!
Old Aug 1, 2012
antrmo's Avatar
antrmo is an unknown quantity at this point
good write up rollondad,my guess was broken wire inside were the door opens at the fender, alot of movement there and wires will work themselves to a breaking point, .open the rubber boot and have a look. cheers,
Old Aug 3, 2012
96ex's Avatar
96ex is an unknown quantity at this point
i agree with antrmo, i had the same problem on my 96 and the wires between the door and fender were loose. so i strongly suggest u check those wires out.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
mdd5
Apr 21, 2015 06:54 PM
skywalker
Nov 8, 2001 05:04 PM
mj1010
Aug 26, 2001 09:52 PM
