Parts Recomendations
I will soon be changing my worn out stock suspension with a full set of Tokico blues and eibach pro kit. I'll also be changing to new mounts and seat springs and switching out both front lower control arms and bushings.
Would it be best to go with honda replacement everything or should I look at Moog or some other name brand, especially on the control arms and bushings?
Re: Parts Recomendations
there is also no need to change out your lower control arm unless they are damaged or bent. you only really need to change out the bushing on them tho. use energy suspension bushings if you decide to change them out.
