speedo not workin
Old Jun 30, 2012
corndog's Avatar
corndog is an unknown quantity at this point
speedo not workin
i got a 98 civic not real sure what model. title says UAX.
speedometer has not worked full time since we have had the car.
i have replaced the vehicle speed sensor. what should i check next?
Old Jun 30, 2012
Re: speedo not workin
Check codes. If there is no P0500, then the speed sensor is working, the computer can see it.
I would pull the gauge cluster out and check for proper power, ground, and VSS signal there before replacing the speedometer.
Speedometer is real common on those.
Old Jul 15, 2012
Trunka's Avatar
Trunka is an unknown quantity at this point
check if the connector plug is plugged in properly and check to ensure that you dont have any broken wires leading to the connector
KikAzz
Sep 4, 2015 12:36 PM
bsmiley
31
Sep 1, 2015 06:11 PM
Brianmc1995
Jun 4, 2015 07:51 PM
crazybluehonda
Canada West
Aug 8, 2002 10:42 AM
bhayes82
Mar 22, 2002 04:10 PM
