speedo not workin
speedo not workin
i got a 98 civic not real sure what model. title says UAX.
speedometer has not worked full time since we have had the car.
i have replaced the vehicle speed sensor. what should i check next?
Re: speedo not workin
Check codes. If there is no P0500, then the speed sensor is working, the computer can see it.
I would pull the gauge cluster out and check for proper power, ground, and VSS signal there before replacing the speedometer.
Speedometer is real common on those.
KikAzz
Sep 4, 2015 12:36 PM
bsmiley
31
Sep 1, 2015 06:11 PM
bhayes82
Mar 22, 2002 04:10 PM
