Cooling Fan Failure
Old May 3, 2012
em2maxamillian's Avatar
em2maxamillian is an unknown quantity at this point
Cooling Fan Failure
I've noticed that while sitting in traffic (when the car is not moving), the air conditioning start to get warmer (it's still cool but not as cold as a moment earlier). I figured it might be the cooling fan malfunctionaing and found out that only one is on (running) when I turn the AC on. The fan on the left of the car operates, but the fan on the right does not turn on at all. I just wanted to know if BOTH fans are supposed to be running at the same time or do they work independently? Would this affect the cooling of the engine as well? I have not noticed any changed in engine temperature whether the car is moving to at a stand-still. Thanks guys! Hope I don't need a new fan...are they expensive?
Old May 3, 2012
Re: Cooling Fan Failure
Oooo, not good. Both should run.
Left and right on any car are always determined from sitting in the drivers seat.
Do you want to change this line now?
With the AC on, yes.
Depends.
Only if you are broke.
When a fan goes out, it usually blows its fuse. Check it. If it is blown, and there is no obvious wiring damage, you can probably assume it needs a fan motor.
Radiator fan:
http://www.hondaautomotiveparts.com/...OR+%28DENSO%29
Condensor fan: http://www.hondaautomotiveparts.com/...DENSER+%281%29
You should look up your own car, I just guessed at one. There may be multiple choices.
The radiator fan is usually the one in front of the trans, condensor fan is usually in front of the engine. You may be able to count the blades on the fan and compare to the pics too.
HTH
MrOldskool
Aug 18, 2015 09:58 AM
FutureCivicOwnr
Aug 11, 2015 10:59 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
