1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 dx coupe
Old Apr 6, 2012
coupedeill's Avatar
not new to this
coupedeill is an unknown quantity at this point
95 dx coupe
Im normally on the 7th gen forums for myself but I picked up a 95 dx auto about a week ago for my woman and i've just started to put some work in. If any of you guys/girls know of some common problems with these cars Please let me know, preventative maintenance is always easier.
So far I've put in new spark plugs,wires,cap and rotor.Just picked up everything for trans fluid and oil/filter change to do tomorrow. Not throwin any codes just want to get her runnin smooth.Its got about 140k miles, fuel filter and power steering fluid are next.
I'd appreciate any input!
Name:	monkey wheels.jpg
Old Apr 9, 2012
coupedeill's Avatar
not new to this
Re: 95 dx coupe
Done with the basics now... Steering still feels a bit stiff and i get a shimmy shake at higher speeds. Tie rods dont have play as far as i can tell, no poping noises or anything during turns so that should eliminate cv joint right? No tears/rips in the boot either. Anyone know some ways to check for other issues...tryin to diagnose from home. Sorry for the limited info.
Old Apr 22, 2012
coupedeill's Avatar
not new to this
Re: 95 dx coupe
Looks like this has also become my "project monkey" car thread...replaced sec of the exhaust midpipe today cause it had a nice hole and installed new mounting clips for the rear bumper as it was sagging and rattling.
Anyway, now with all that noise gone I can now hear multiple popping sounds when making sharp turns at low speeds. With a little effort I can get some play pushing in on the right and left of the wheels when on jacks. No noise when im turning at higher speeds or going over bumps, having stiffer steering though. Everything looks ok, no cracks or tears in boots. Again any help would be appreciated.
Old Apr 22, 2012
Racin97's Avatar
Racin97 is an unknown quantity at this point
Re: 95 dx coupe
Unless you know the timing belt was just replaced you need to change it the water pump and the cam/crank seals or it will eventually leave you stranded
Old Apr 23, 2012
coupedeill's Avatar
not new to this
Re: 95 dx coupe
Timing belt/water pump and seals were done already so im good like that. Thanks for the response though...only 200+ views before one haha.
So after hours of searching this site and many others and doing a lot of tests Im sure my problem is right side CV axle. I picked up the whole CV shaft for the passenger side today... now Im out to the garage with DIY instructions in hand. First time doin this so Im prepared for a few hours of fun.
Old Apr 24, 2012
coupedeill's Avatar
not new to this
Re: 95 dx coupe
Cursed my way through it but got her done, took about 2 1/2 hours, not that bad for my first time...i think anyway. knocking is gone
Picked up some all seasons to get mounted tomorrow- Im thinking that will solve my shimmy as the ones on now are worn and bit uneven too. If that works out I'm pretty much done.
bmwstar98
Aug 16, 2015 02:28 PM
Snax
Aug 12, 2015 10:23 PM
Curtchuk
Aug 5, 2015 02:14 PM
viperGTS
Jul 27, 2015 08:38 PM
Nalmonte
Jul 22, 2015 09:08 AM
