Longer Tie Rod Ends? More Threads?
Recently dumped the civic and got him on to the alignment rack last night. I found that because of the changed geometry from the drop and the positive camber adjustment up top, I run out of threads on my outer tie rods to set my toe correctly.. I end up maxing out and unscrewing the inner and outer before I set the toe in straight. What i end up with is both sides almost 2 degrees negative toe.
Ive searched and searched but no one seems to have tried aligning their car after a sever drop? I see that the EP3 tie rod ends will thread on but are they longer or have more internal threads?
HELP. Thanks guys
Re: Longer Tie Rod Ends? More Threads?
they talking about the RSX tie rod ends in these pages...
I am not that dumped, just the eibach prokit, so don't know that much about. inverting the rods will also change the distance from the steering box, giving slight more adjustment for you
the meager negative camber gain from drop does not play much in strutted suspensions.
Ok... But what ive gained from that thread is that EP3 and EM2 share the same diameter hole on the steering arms and the DC5 is a bit larger and will not fit.
Anyone else?
Anyone else?
I would think that if you were use a coupling nut with a male and female end, you could extend the factory tie rod arm to give you more thread.
I tried a quick search and they seems pretty rare, unless I don't know the exact name they go by, then you'd just have to find the right thread type and desired length.
Bottom one.
Bottom one. Re: Longer Tie Rod Ends? More Threads?
Possibly shock extensions, but we would need something larger than the upper strut mount bolts.
I'll be going to a fastener warehouse soon, does anyone know the tread size and length of the tie rod end?
Bottom one.
OMG, dad owns a machine shop..LOL ya, definitely just make something!
You just need the thread size and appropriate grade metal.
Make me a set too!
Make me a set too!
Edit:IF you have D2 coilovers i guess. Thought about this statement^. Perhaps other companies have the steering arm designed at a different angle to fix this..
If you really want them I wouldnt mind sending you a pair for cost either. Im wondering why no one else has chimed in.. If you have a lowered EM2 you are going to need these to have correct alignment?.. Do people have tire hookups i dont know about?!
What about just inverting outer tie rod and not the inner tie rod bracket?
I would imagine that you could bottom out the standard ground control coils and get away with inverted rods...but I haven't done it myself. Once spring comes around and I roll my front fenders, I'll very likely find out lol.
That, I'm not sure of. I only know about the DC5 inner bracket because it's what someone did with his Em2, which sits about 1/2" off of the ground on GC's with Tokico D-Specs, which have the standard steering arm on them...other than inverted rods and an extended inner bracket, and upgraded bushings and smaller springs, he's really done nothing else to achieve that drop.
What are you rolling fenders with?
)I do however; believe that perhaps DC5 or other outer tie rods could be designed different and work being inverted? I think i will just make a set of the male/female couplers and give them a go.
Interesting... I think in our case (OE Em2 parts) the outer tie rides are somewhat symetrical so I do not see where inverting them would change an orientation for a gain. I put my OE struts/shocks back on for now until i can gather everything else I need (rear camber kit as well..
I rear camber kit is definitely a good idea :P I picked up Megan rear arms for $90 plus shipping on eBay, so they are very affordable.
What_It_Do, I'm pretty sure that's that's the guy - I do remember the extended ball joints now...also, the strut mounts are far from OEM, which I also forgot...it's pretty impressive how he managed to get that car as low as it is...I drive my car too much to have it that low lol.
Also, a guy from another forum who lives nearby is splitting the cost of renting a fender roller in the spring, and we are going to use it to do our fenders
You buying the EastWood Fender Roller?
I can rent it for $60 if you are interested we could do all three and it be $20 a piece.
Can do it at my place, or bring it up where you live.
Also got the thread size of the tie rod end.
I bought a tie rod and confirmed at two places that the thread size is:
M14x1.5
Get to work.
M14x1.5
Get to work.
M14x1.5
Get to work.
M14x1.5
Get to work.
I've thought about modifying them since I was all ready rubbing, and I'll be dropping even lower. Or just removing them..lol
I'm probably gonna end up removing mine, seeing as how I don't want to get into making something custom in that area....just gotta replace my front slash guard at least, 'cause it's not on the car.
M14x1.5
Get to work.
M14x1.5
Get to work.
Sorry to resurrect (not that I agree/disagree with "resurrection" reasons) but here's final info on this topic...
SORRY HADTO DELETE LOL I THOUGHT THIS WAS A EP3 THREAD. ANYWAYS, GODSPEED TIE RODS
blouisgod
Jul 1, 2007 08:26 AM
