flywheel/crankshaft alignment
Old Dec 7, 2011
jiggernaut's Avatar
jiggernaut is an unknown quantity at this point
Hi,
I'm replacing the clutch on my 04 civic. I'm currently installing the flywheel to the crankshaft and I was wondering if the flywheel has a certain orientation on the crankshaft? or can it be installed in any position. I didn't mark it as I was expecting a dowel pin in the crankshaft.
Thanks in advance, jig
Old Dec 7, 2011
Re: flywheel/crankshaft alignment
If there is an offset bolt hole, then it will only fit one way.
If it will bolt on in any position, then it does not matter.
Old Dec 8, 2011
jiggernaut's Avatar
Thanks, ezone
I don't have any offset bolt holes. I also read that the 1.7L is internally balanced so, i'm bolting it up.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
