flywheel/crankshaft alignment
Hi,
I'm replacing the clutch on my 04 civic. I'm currently installing the flywheel to the crankshaft and I was wondering if the flywheel has a certain orientation on the crankshaft? or can it be installed in any position. I didn't mark it as I was expecting a dowel pin in the crankshaft.
Thanks in advance, jig
Re: flywheel/crankshaft alignment
If there is an offset bolt hole, then it will only fit one way.
If it will bolt on in any position, then it does not matter.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
TheRiddicles
Sep 21, 2015 01:28 AM
