Sponsored by:
Sponsored by: CARiD
Hub Rings
Old Apr 30, 2002
Eman's Avatar
Eman is an unknown quantity at this point
Hub Rings
Whoopppyyyy....I got my 17" Konig Verdict in Black Opal the other day and the guy I bought the rims from included a set of Hub Rings. He said that it will make the wobbling disappear from the new rims. Any opinions on these?
Old Apr 30, 2002
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
put up a picture or link
Old Apr 30, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
wobble?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 30, 2002
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
I read an article in Import Racer and they installed a set of 17 in rims on a 6th Gen. They used hub rings for whatever reason and they were supposed to help with the balance on that type of rim. I will look at the article tonight and get back with you....
Old Apr 30, 2002
klam's Avatar
klam is an unknown quantity at this point
You need to use the hub rings to have your aftermarket wheels centred properly. The reason is that most aftermarket wheels are lug centric, and it's hard to get it aligned properly like that without hub rings. I went through the same mess.
Old Apr 30, 2002
mohawkboom's Avatar
your OEM tires are sitting on a ring that protrudes a little with the tire off. Most aftermarket rims do not sit on that ring and all te wieght will be supported on the lugnuts(not relly good) The ring they give you fill the space between your OEM ring and the larger one on the rim..(most cars mounting ring is larger than 4 bolt honda setups, so rim molds are made with those designs in mind.
CHeers
Mohawk
Old Apr 30, 2002
Deejai35's Avatar
You guys are automotive prodigies...[IMG]i/expressions/face-icon-small-smile.gif[/IMG] I just read the forums and the questions posted and soak in all the wisdom of my peers (and seniors). Really though... I commend and look up to you guys....
Old Apr 30, 2002
mohawkboom's Avatar
Keep sponging what we say and you'll be just like us soon enough [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 30, 2002
Eman's Avatar
Thank's all!
I'll put up a picture once I have it on.
califcamper
Suspension
Apr 11, 2016 03:43 PM
danace99
Oct 17, 2015 02:51 PM
siliconvalley
Sep 15, 2015 09:48 PM
Strycker
Aug 18, 2015 02:25 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
