Do Coupe sideskirts fit on a Sedan?
i am not sure man, but i think not. For example the kaminari side skirts wont fit, cause the coupe has a gap between the the door and the rear fender where it fits, while the sedan doesnt have a gap and have a door instead.
Hope this helps!
Hope this helps!
sedan and coupe sideskirts are the same length, however, not all coupe skirts will fit a sedan because they are designed to fit around only one door. you make them fit with not too much modification, however. the wwg5 skirt wont fit a sedan unless you cut the part that goes behind the door.
SoyerOner
May 11, 2015 09:46 PM
aus10
Apr 13, 2015 09:26 PM
