DC Sports header problem
Old Apr 29, 2002
ELTsanwich's Avatar
ELTsanwich is an unknown quantity at this point
i just installed my dc sports header and i can feel exhaust coming out and it sounds like a lawn mower. i have the bolts tight did i forget anyhting????
Old Apr 29, 2002
AlexLx's Avatar
AlexLx is an unknown quantity at this point
my only suggestion would be to inspect your factory gasket. A new one may stop some leaks.
Old Apr 29, 2002
Pir8pete
Guest
Posts: n/a
try useing a gasket or get the same material and cut the shape out [IMG]i/expressions/face-icon-small-smile.gif[/IMG] and maybe touble it up!!!!! to fill the gap
It's the after market world, they seem to make product some times a bit worped [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Apr 29, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
what do you mean a lawn mower??? i hear cars that sound like mopeds
anyways i dunn have a lawn mower but i guess you are right it might be something wrong with your own car not the header
Old Apr 29, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
The top gasket is metal.....so that shouldn't be a problem...I just installed my HP header with 24,000 miles on my car and no problems......and the same goes for the lower donut sealer at the bottom..........so here are the simple quesitons first:
1. Did you put both gaskets on?
2. On the lower did you put the donutsealer on the DC header first then bolt it on
3. Did you tighten all nuts good???..tighten in a sequence center to outward..ten re-check after you drive a while
4. did you reinstall the bolts that hold on the heat shied...that give added securement as well???
that is all I can think of that might be your problem...good luck !!
Old Apr 29, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
hope you fix the problem man...
Old May 7, 2002
Pharoh's Avatar
Bobaganoosh!
I would agree ALLMAN. You would be suprised what can happen if you tighten the bolts in an improper pattern, kinda like putting on your wheels, fastening and torquing them in the wrong pattern.
Old May 8, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
check the doughnut shaped gasket on the lower connection, its kinda frigale(sp?), could be a leak there.
Old May 8, 2002
Maverick's Avatar
Maverick is an unknown quantity at this point
you definitely forgot to put the lil round gasket on from the lower end of your header, that's why it sounds like that. if it was a leak, it would have sounded like that before. common mistake, you'll be alright and soon happy with your header
Old May 9, 2002
dcsportsgirl02's Avatar
dcsportsgirl02 is an unknown quantity at this point
on the factory header there is a dounut gasket on it, take it off and put it on the dc header and it shouldn't leak thats what did to mine
SugarRay
Dec 13, 2001 09:58 AM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
Maximus
Nov 18, 2001 03:55 PM
mattskav
Nov 8, 2001 10:44 PM
Lightman
15
Nov 8, 2001 05:06 PM
