Plugs, wires, or coil packs?
Old Sep 8, 2011
Runrobrun's Avatar
Runrobrun is an unknown quantity at this point
First off, I'm a noob, both to this forum as well as DIY auto maintenance. I've got a 2003 civic ex with 140,000 miles. For about a year, the cel has come on, gone off, come on, gone off, etc. Since I live in CA and needed to get my car smogged, I figured I should probably look into the problem. I bought a code reader and it read 6 codes, p0300 - p0304, with 0304 read twice (?). 2 minutes of research told me that a likely cause of these codes is bad spark plugs. I have never had mine changed, so this seemed plausible. Did that 2 days ago and the cel went off. It came back on today as I was puling away from a stop sign. When I got home, p0304 came back. 2 more minutes of research told me a second likely problem was the coil pack. I swapped out the coil pack from cylinder 4 with cylinder 1, and erased the code. If the cel comes back with code p0301, I will know I have a faulty coil pack, if p0304 comes back does that point to the plug wires? If my logic is faulty, please steer me in the right direction.
Old Sep 8, 2011
CraigW's Avatar
Re: Plugs, wires, or coil packs?
Coil on plug eliminates plug wires.
See what code you get and go from there.
Old Sep 8, 2011
Runrobrun's Avatar
Like I said, I'm new to this, so I probably got my terms wrong. Are you saying that the coil pack (tube that fits over the spark plug inside the spark plug cylinder) takes the place of spark plug wires? What about the wire harness that the coil plugs into? Could a malfunction exist there that would cause a cel to come on?
Old Sep 8, 2011
the wire harness is usually never an issue, those are low voltage wires. all the action happens in the coil pack (which replaces the distributor and wires of older cars). and ofcourse there are four coil packs one for each plug. its way more efficient technology.
Old Sep 8, 2011
BlueEM2's Avatar
Whachya lookin at?
If you had coil pack issues you'd know believe me. The car would jerk and throw you around and it wouldn't be driveable. They are designed to last the life of the car and never really need to be replaced unless defective or they have premature failure. But again, you'd know if a coil pack was shot. The coil pack (and a few sensors) replace the plug wires and distributor under the hood. You do however need to figure out where the code is coming from, you didn't by chance use bosch spark plugs did you?
Figures gearbox beat me to it!!!
Old Sep 9, 2011
Runrobrun's Avatar
I did use Bosch. Tell me more.
Old Sep 9, 2011
BlueEM2's Avatar
Whachya lookin at?
They just dont fair well on a Honda.. Replace them with NGK or Denso
Old Sep 9, 2011
CraigW's Avatar
Get some oem plugs.
Old Sep 9, 2011
Runrobrun's Avatar
Could using a Bosch plug cause the cel to come back on that quickly? I have no problem replacing them if I need to (lesson learned). I just want to make sure I am not overlooking something else. Thanks for all the replies, btw.
Old Sep 9, 2011
yes i have heard of new bosch plugs causing misfires before in hondas
Old Sep 9, 2011
Un4givenshadow's Avatar
Un4givenshadow is an unknown quantity at this point
It happens all the time. As was already said, Bosch+Honda=Not best friends..... NGK+Honda=Bff's
Old Sep 9, 2011
Runrobrun's Avatar
Crazy. I'll give it a shot. Thanks. Before I tackle next week's project, is there a brand of brake pads I should buy?
Old Sep 9, 2011
stick with the honda pads
Old Sep 14, 2011
Runrobrun's Avatar
Changed out the Bosch plugs with NGK platinum plugs. I was surprised how discolored the threads were on the old plugs. They look similar to the original plugs I took out only last week. Is this discoloration normal? I read the cel codes just before pulling these plugs and it read 5 (p0300-p0304). I have cleared the codes, so I guess I can only wait to see if they come back.
Old Sep 14, 2011
plugs are supposed to be light brown mostly and maybe some black around the threads and base.
Old Oct 19, 2011
Runrobrun's Avatar
I switched to the NGK plugs and the cel went off....for about a week. I heard that corrosion on the battery terminals could cause the problem, which I had. Cleaned off the terminals and the light went off (prob because I disconnected the battery in the process, no?) but it stayed off for two weeks this time. Light came back on today, pulled the codes: p0300, p0304, p0303. This time, the car is not sluggish at all. The only symptom I am noticing, and I don't know if it is related at all, is that there is a strong exhaust odor at idle. I had not noticed it before, but that doesn't mean it wasn't there. Any ideas? Thanks in advance. Rob.
Old Oct 20, 2011
Runrobrun's Avatar
Light went off today. What could cause the code to come and go intermittently?
Old Oct 21, 2011
check to be sure the factory ground wires are tight and not corroded.
Old Jan 23, 2012
Runrobrun's Avatar
After changing both upstream and downstream O2 sensors, the CEL has been off for over a week. However, a new symptom has emerged. After cold starts, there seems to be a delayed throttle response in first and second gear. During the delay, I can mash the accelerator and there is no response. If I were not to depress the clutch, the car would most certainly stall out. After the delay passes, the car runs fine. still no CEL, and the ECU is showing no code. Is this a different issue altogether or a symptom of the same problem? I would appreciate any thoughts. Thanks. Rob.
Old Jan 25, 2012
04 Honda Civic's Avatar
What type of O2 sensord did you use?
Old Jan 25, 2012
Runrobrun's Avatar
Denso. Exact fit oem.
Old Jan 26, 2012
beastyben1's Avatar
beastyben1 is an unknown quantity at this point
Any problems with the heater? Consistent?
I recently had all those exact codes...air in the coolant system caused by a bad head gasket. Codes haven't been back on since the repair. I read somewhere the air gap can cause the misfire codes via the temp sensor.
Old Jan 27, 2012
The NGK plugs you used should be
NGK: PZFR6F-11
If you want to use Denso the number is
DENSO: PKJ20CR-M11
This is what the book calls for, anything else may cause misfires.
Gap is 0.039 to 0.043 however you really shouldnt gap irridiums hence why buying them from the dealer is a very good idea.
Check for vacuum leaks
Cleaning your throttle body and IAC would be a good idea. (Probably will help the problem but not solve it)
Old Feb 14, 2012
scooty's Avatar
scooty is on a distinguished road
The misfires you had earlier meant that cylinder was running rich. Might have clogged the catalytic converter. That would explain the sluggishness.
Old Mar 16, 2015
hdgodfrey's Avatar
hdgodfrey is an unknown quantity at this point
When you had this issue did you also have intermittent heat?
Old Mar 16, 2015
beastyben1's Avatar
Yes, I also had intermittent heat.
Old Apr 3, 2015
Amiri H's Avatar
Amiri H is an unknown quantity at this point
Talking Re: Plugs, wires, or coil packs?
hey guys,
2003 civic need to do a tune up ,
will be required ? if possible any links to product ..
so i can search them up and order them online as the mechanic are a rip off.
thanks H crew
Old Apr 3, 2015
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Originally Posted by Amiri H
hey guys,
thanks H crew
How many miles do you have? When was the last 'tune up'?
Old Apr 3, 2015
CraigW's Avatar
......and has the timing belt been replaced ???
Old Apr 3, 2015
Amiri H's Avatar
@ theshushiboy -
it has 277202 km = e - test was recently done. and i just purchased the car.
@ CraigW - not sure as its a recent purchase and havent had time to visit the mechanic ,
