Plugs, wires, or coil packs?
Old Apr 3, 2015
  #31
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Re: Plugs, wires, or coil packs?
Originally Posted by CraigW
......and has the timing belt been replaced ???
This is your first concern. If the belt breaks while you're driving, you'll be in a world of hurt. It PROBABLY is good, but you'd be daft not to replace it. It's a weekend job.
IMHO, I'd do the following, regardless of who told me what when I bought it:
Replace plugs (NGK)
Trans oil change (flush at a shop)
Engine oil/filter (I go Mobil 1 with matching filter, but that's preference.)
K&M 1,000,000 mile filter
Radiator flush
Check brake pads/shoes
Check p/s, p/b color
Check underside of belts.
Find out about timing belt change. With proof.
Anybody else chime in?
Old Apr 3, 2015
  #32
mikey1's Avatar
timing belt ASAP....
along with tensioner, tensioner spring, water pump and drive belts
new honda coolant (will need to drain to replace water pump)
Wild Cranker
427
Jan 28, 2016 06:49 PM
danace99
23
Jun 28, 2015 08:49 AM
Blaster30
Apr 22, 2015 12:21 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
