Yeah, another camber/tire wear thread
Old Aug 2, 2011
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
A while ago I researched camber settings on this forum and found some good info from someone with a similar setup as mine (KYB AGX with Eibach springs and 205-60R15 tires). The other user had a camber setting of -1.2 front and -.75 rear. I have been using this spec for years now with different tires and have been happy. This past set of tires I had other issues to deal with and did not rotate as I should have. When I finally got the front tires replaced, the interior was dead bald, the center of the tire was very worn, and the exterior still had some tread. I was thinking bad camber and got an alignment. The starting specs were -1 camber and -.02 toe for left and -1.6 camber and -.12 toe for right. The left was close to set spec, but the right was a bit out. Yet both tires "looked" the same, or very similar. I have always heard toe eats tires faster than camber, but the inner wear is from camber.
So did my fronts get eaten because of the camber, or because of lack of rotating? I would guess rotating to the rear with less camber would help reduce inner wear, but the inner will still wear quicker than the outer. Should I reduce camber to save the tires? I live in TN and truly enjoy the curvy roads, so the camber is a benefit for daily driving. It's just with the price of tires going up, they need to last at least a while.
And when did the price of tires get so high? I was going to get a set of Falken tires this past time and they were over $100 each. For $100 a tire, I'm going Michelin. But of course Michelin discontinued everything and I ended up with the Pilot Exalto. I had already purchased the tires before I found they are the stock tires for new Civics. Well, now I'm stuck with them for a while.
So in a nutshell: Should I reduce camber? Is there a good decently priced tire out there?
Old Aug 2, 2011
Re: Yeah, another camber/tire wear thread
this is from me other thread, but i think this applyes to your case.
Originally Posted by sdaidoji
Heh!
This is for the guys that come here saying:
My car have something wrong in teh suspension! Or : suspension is making noises! Or: I can't align the car!!!
Etc, etc.
Well, i had a "small" encounter with a curb just after buying my miata (bald tires from PO, etc) and the car always was kinda strange to drive, some insecurity when turning - i can push the civc much harder than i can the miata. Very strange, actually, miatas are supposed to be much faster in corners.
After a few years, since i was able to align it, i never looked too close to it.
Well, i got new control arms (all 8), and was disassemblying them.
Heh! found the culprit! Control arm to the knuckle bolt...
So, bottom line is: whatever you ask here, replies are simply... worthless if the guy asking did not inpect nor did disassemble the parts.
I put the new control arms side-to-side with the removed ones and they seem all perfect.
What was not "perfect" was this bolt... And it was not visible from the outside.
So, if you are going to ask what's wrong with the suspension, just don't, and disassemble it, inspect and then post here.
Could be anything.
So, start checking your bushings, etc, etc. Could be anything going wrong. Especially if it was working before but not anymore. something on your car is not straight anymore.
Old Aug 2, 2011
bobsagator's Avatar
Thanks sdaidoji. Last summer I had an incident that led to replacing front hub bearings and LCA bushings, and the camber bolts. Since the fronts only have the camber bolt, I don't see how there could be any damage similar to your Miata's bolt. I am hoping it was just a "too long with no rotation and alignment" problem, but jsut don;t want to keep eating tires.
And dirty red, search button is your best friend...
Old Aug 2, 2011
the bolts on the miata are just examples. civic case could be worn bushings (likely) or other stuff worn or damaged, so recommend taking stuff apart once (not as much work as my miata, actually ) and inspecting them. Could even be bent arms. Mine arms i had one cracked
Yeah, i know, lazlong, here it goes for the 4th time!
Again, it could be anything wrong in the suspension.
so check the ball joints and other stuff too,even the top mounts... like i said, took some years until i found out the real culkprit, because i never took the arms out at this level before. I had more time since my tires were wearing normally, though.
Mods, thanks for the quick response on the third unruly member that invaded here
Old Aug 2, 2011
ah, tire prices have been going up 3 or 4 times a year... supplier prices (they are mostly foreigner suppliers...and dollar falling, including debit ceilings to help...)
Old Aug 2, 2011
maxtierney's Avatar
EM2ti
I'm currently running close to -2 degrees front static camber with 0 toe. I wear pretty evenly across the tire. The movement of front suspension (and dynamic camber encountered with driving) is vastly different than the rears.
IMO, it is more likely to get inner tire wear from running with worn front rubber bushings (dynamic toe out would cause a "more even" wear rate, than your mismatched static toe would lead you to believe). My old alignment guy used to dial in less camber and toe on the driver's side to compensate for my weight.
Worn struts could also contribute. How's you damping?
Dial the toe to 1/16 or 1/32" inwards, (I don't know the measurements in degrees). This setting should zero out while driving. Does your car pull? Toe in reduces any wandering and/or pull.
As Sdaidoji said. Give your suspension a once over, it never hurts.
Old Aug 3, 2011
sl33pyriceboi's Avatar
you can run up to -3 degrees before drastically reducing tire wear.
Old Aug 3, 2011
bobsagator's Avatar
I would love to take a weekend to dismantle the suspension, but I already have too many ***** in the air. My repalcement tranny is split open awaiting new bearings, I am diagnosing a probable head gasket leak, my A/C clutch flew off and needs to be replaced, throw in a wife and kids and the suspension takes a back seat. But as I said, everything except the struts are new as of last summer. When I pulled the LCAs they matched up so one is not bent (at least any more than the other one...).
If up to -3 is relatively acceptable, then I guess I will keep the -1.2F and -.75R settings and be more diligent on alignments and rotating. Hopefully the tires will thank me in the end.
On a side note, when I got the alignment this past time I didn't take my settings with me. I stood there at the counter and remembered the -1.2 and -.75. Sadly I gave them backwards, so I am now riding with -.75F and -1.2R. Let's just say there is a big difference. I looked last night at the specs and realized they were backwards, and gave myslef a big slap on the forehead! The corners are sloppy and it feels like it is pushing more. I am hoping realigning with correct specs will take it back to normal at least. I still think the sidewalls of the Exaltos are too soft and allow too much bodyroll.
beeemerdude
Jul 23, 2015 03:53 PM
suburbanite
Jul 17, 2015 03:05 PM
