RSX Rear Brakes Fit?!?!?!?!?
Old Apr 27, 2002
Pir8pete
Guest
Posts: n/a
I know there's no drum-to-disc brake conversion kit out for hour cars yet, but will the rsx hardware from it's rear disc brakes fit on are cars. What mods would i have to do to make them fit. I know that the 7thgen civc's are on the same plateform as the rsx.
or will the new Si's rear bakes be a better fit?
Old Apr 27, 2002
Grey's Avatar
DIY King
Does the 2002 Si have 4 lug nuts? I don't know off hand? Anyway, the RSX has 5 lug nuts, so you'll need the RSX's hub assembly and everything else. Shouldn't be hard. Shouldn't be that expensive either. Check out www.acuraautomotiveparts.net for parts and prices.
Old Apr 27, 2002
icey's Avatar
icey is an unknown quantity at this point
damn i wanna do a conversion real bad..cant stand to look at the drums...although i've paitned them so at least they are not rusty...just disks look so much better =)
Old Apr 27, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
ya, the new SiR has 4 wheel disc, and they are 4 lug.
Old Apr 27, 2002
Hatchcivic's Avatar
Hatchcivic is an unknown quantity at this point
the 02 si has 4 lug nuts rsx has 5, but its basically the same suspension and brakes just the rsx has a different spindle that has 5 lugs on it
Old Apr 27, 2002
C2i0v0i1C's Avatar
SuperMODrizd
might want to check the AEM website about that rear disc conversion, from the looks of it to me there is one or its in the making
Old Apr 29, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
first, the new SI's may work, same lug patern and suspension, and second, and even easier id think.....get rear ACURA EL rear discs......they cant cost too much for either of those
Old Apr 30, 2002
dragoon's Avatar
though Acura EL, Civic SiR/Si and RSX rear discs may fit, do the discs provide a significant increase in stopping power? if they do, wouldn't they warrant replacing the front discs to match, also? IMO, our brakes are excellent as they are, though the drums ARE pretty [IMG]i/expressions/face-icon-small-puke.gif[/IMG]
Old Apr 30, 2002
Grey's Avatar
DIY King
I don't think the Acura EL has different sized rotors in front. I'm almost sure the '02 Si doesn't have bigger rotors up front either. They're just cross-drilled. I'm not sure about the size of the RSX rotors in the front, but I think that they're the same size as well.
Old Apr 30, 2002
dragoon's Avatar
doesn't the RSX-S have big slotted rotors up front, though? that'd be
Old May 1, 2002
jaje's Avatar
jaje is an unknown quantity at this point
the 94-01 integra (gs/rs/ls/gsr) and the 92-00 civic ex/si all had the same 11" front discs and 9.5" rear discs...only the itr had larger 12.1" fronts that it shared with the accord wagon, accord v6s, and prelude vtecs
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Poopies
Apr 20, 2017 11:36 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
cmart1209
May 29, 2015 04:52 AM
CivicHX01
25
Nov 18, 2003 09:40 PM
