condenser fan
Old May 18, 2011
zuk16l's Avatar
zuk16l is an unknown quantity at this point
condenser fan
Any tips on replacing a condenser fan in a 2001 civic. Doesn't seem to be enough room to pull fan out the top. Does the bumper cover need to come off? Does fan come out from bottom?
Thanks,
Travis
Old May 18, 2011
lazlong's Avatar
Re: condenser fan
1. Remove bumper and grille
2. Disconnect fan connector
3. Remove upper radiator brackets (2)
4. Pull radiator forward and you should be able to sneak the fan out of there. If you can't just disconnect the upper radiator hose for more room.
Old Nov 27, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: condenser fan
I know this threads over a year old, but it's what my issue is about.
Is the above true for the condenser fan or the radiator fan? The condenser fan looks like a PITA to remove compared to the radiator fan. I'm about to replace my rad and I'm concerned about getting the condenser fan out of the way or moved enough to get the ATF pipe past it if I can't remove the fan.
I tried looking for some clear instructions specifically for the condenser fan in the service manual on removal, but did not find any.
Any info is appreciated.
Old Sep 6, 2014
rusty1161's Avatar
rusty1161 is an unknown quantity at this point
Re: condenser fan
Again, this is an old thread but looking for any tips or tricks to replace the condenser fan on a 2001 Civic. It looks tight!
Thanks.
Rusty
Old Sep 9, 2014
lazlong's Avatar
Re: condenser fan
They will both come out the that way. If you can't get it out that way you're gonna have to remove the radiator. Good luck.
Old Sep 12, 2014
rusty1161's Avatar
Re: condenser fan
This, plus removing the condenser brackets to allow it and the radiator to lean as far forward as possible worked for me. Thanks for the tips!
Rusty
h4ldol
Apr 24, 2017 08:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
Scout1
Oct 5, 2015 01:33 PM
anubis62
Sep 27, 2015 12:56 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
