What needs to be done on '00 Civic LX with 14K miles?
I was hoping to get clarification on what, if anything, needs to be done on my car.
I just bought a 2000 Civic LX with 14,000 miles on it last week. It passed the NYS safety/emissions inspection.
My dad was the one who brought the car in for the inspection, and I looked at the paperwork afterwards where the dealer that did the inspection said that, "based on the mileage, the manufacturer recommends" the following actions:
- service air cleaner
- rotate tires
- wheel balance
- inspect exhaust system
- inspect shocks, suspension, steering
- tune-up
- service windshield wiper system
- replace windshield wiper blades
- service AC
- adjust parking brake
- drain and flush cooling system
Does that sound about right or does that sound excessive?
The owner's manual mentions on p. 178 some of these things, but not all of them.
And will it be crazy expensive? (I feel like I've been bleeding money after shelling out for a car and its associated costs, and I'd prefer not to bleed a few hundred dollars immediately, but I do want to do right by my car.)
As for background about the car, I don't have the service records unfortunately. I bought from a private small dealer. The previous owner was a little old lady, and the AutoCheck score was 89 whereas similar vehicles scored in the range of 34-58. I had a mechanic look at the car when I went to see it, and it checked out...but he's an acquaintance and I wasn't like paying him for an inspection on the spot...so I trust his opinion but it'd probably be different from actually taking the car in, right?
Thanks so much for helping me out!!
- rotate tires
- wheel balance
- tune-up
- service AC
Re: What needs to be done on '00 Civic LX with 14K miles?
Soundsd okay but you can do all that yourself in a matter of a few minutes except the wheel balance that i personally wouldnt do and the "AC" service that they don't do anyway. They will probably want around 100 bucks for it all i think.
When I buy a "new" used car, I usually do a visual inspection on such things that were listed.
I change the oil and filter, inspect/replace the air filter, check coolant, check tranny fluid (drain/refill if auto)
I wouldn't do the balancing of the tires, unless the ride is bumpy and feels like they are out of balance.
Check the tread on the tires to see if they are all even wear. If not, you can rotate them as needed (or alignment if worn uneven or cupped)
For it being 11 years old, I would do the tune up even though it has low miles.
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
tylerginevan
Apr 27, 2015 12:29 PM
streetglower123
Apr 12, 2015 10:56 AM
