Fuel additives/Fuel injector cleaner safe?
I have tried looking this up everywhere but can't find any info on it.
I didn't know where to post this either, but is using Fuel injector cleaners/fuel additives safe for the 8th gen 1.8 Civic LX??
I was thinking of maybe running some Seafoam through the gas or maybe some Lucas Fuel Treatment/injector cleaner.
Are they safe? Thanks
Re: Fuel additives/Fuel injector cleaner safe?
I don't ever plan on running it through the vac. system or oil...I would only add a little bit to the gas, but thanks for the reply
far as i know, the cleaners are safe to use. I use from time to time, no problems whatsoever.
My injectors got slightly biggers, though (Last sentence is a joke!!!)
ive been using lubecontrol.com additives in oil and gas every day for 5 yrs and no problems. theyre the only additives i would recommend for long term use that actually work.
If you ever use any type of fuel injection cleaner or engine oil flush, and you notice any improvement, then your fuel injectors or engine were clogged up to begin with. Look into why your having such problems.
If you keep your motor tuned up properly, and suddenly notice a drop in gas mileage or rough running engine, then try adding FI cleaner and see if mpg returns to normal.
Pouring any cleaner into the power brake booster line does not make any sense to me because there is no guarantee it will get to all the internal engine parts equally.
I add FI cleaner every 10 to 20k miles. I run a full synthetic oil so I don't ever have to run a flush through the engine.
I don't notice any drop in MPG...just want to make sure the injectors stay clean or if there is a little build up, remove it all with a bottle of FI cleaner
Check your gas mileage when new (after break in) or after a full engine tune up. Compare it to similar cars. As long as your getting normal gas mileage, you don't need to add FI cleaner.
Keep track of how many miles you drive between needing to add FI cleaner. Determine for yourself how often you need to add it. Some people say every tank, others never use it at all. Driving conditions, cars, and gas varies.
Live for the Twisties
My only comment would be that using good quality gas and oil is far more important than concerning yourself with additives, preventing the contaminants from entering the system is better than trying to clean it out. That means transitioning to group IV or V synthetic oil early in the engines life and exclusively using Chevron or Shell gas.
Did you know that American gas has much lower regulatory standards than Canadian gas, thats one of the reason American imports aren't worth much here and anyone who does import a car usually changes the fuel filter immediately. Quality gas is seriously important.
I use Shell or Chevron as much as possible. I try to use a brand that advertises some additive that acts as a FI cleaner. I also use Amsoil extended drain oils.
My last two cars, here in Southern California USA, had 95 K miles on them when they were totaled in separate accidents (other guy's fault). My current car has 85,000 miles without any FI problems. How much better can cars/gas in Canada be?
Gas formulas have no effect on the fuel filter. Liquids pass through the filter unaffected. The filter will trap sand and grit particles that get into the system from the outside environment. For example, if you open the gas cap of your car during a dust storm, dust will get in. Rust inside gas tanks is another contaminate that can clog filters.
A big factor in fuel filter life is if the gas pump actually has a filter or not. Some brands of gas pumps have caps that can replace the filter. Some gas station owners remove the filter to save costs of labor and filters.
Never get gas immediately after a fuel truck has dumped fuel at the gas station. That stirs up all the contaminates in the bottom of the underground gas tank which is then pumped directly into your car's gas tank if the filters at the pump have been removed or bypassed.
Ever tried to pump gas into your car and the flow of gas was very slow? A clogged pump filter will cause the slow down. At least you know the station owner is using pump filters.
I worked on gas station pumps and equipment 30 years ago.
BG 44K comes in a can very strong Concentrated Proffesional Grade
Very strong But very safe to use as well. this stuff can be a little hard to find just google BG find a shop for nearest location to You. pour into the tank "BE CAREFULL NOT TO GET IT ON PAINT..!" or it may damage it. pour in and drive works AWESOME its what I use. and really notice a difference.
GritzNGravy
Aug 19, 2015 03:03 AM
Green02civic
Jul 27, 2015 10:48 PM
