99 Civic lower oil leak???
Old Feb 7, 2011
tjb101084's Avatar
tjb101084 is an unknown quantity at this point
Just picked up a 99 civic EX auto with 98K miles and SUPER CLEAN. Everything is perfect except a small oil leak from the lower portion of the moter. Lifted it up today to take a peek and seems to be coming from where the engine mounts to the trans. This commen? I get its high miles but was woundering if something else from that area tends to leak?
Thanks for any help
Old Feb 7, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: 99 Civic lower oil leak???
if its coming from where the engine mounts to the trans that that is likely a rear main seal leak, its not a terrible thing to change but the trans will have to be dropped in order to do it, which if you can do it yourself is not so bad, if you have to pay a mechanic then it can get costly. Are you running synthetics or natural oil?
Old Feb 7, 2011
tjb101084's Avatar
just bought it so its nat oil. Wounder what the labor is? I can spare a few hundred if thats all it is.
Old Feb 7, 2011
Newfiedan's Avatar
minimum 6 hours labour to remove trans, replace seal and reinstall, most shops will charge you around 8 to do it so judge accordingly this is just for labor not parts.
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
mistermenphis22
Apr 3, 2016 08:06 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
Lightman
Nov 10, 2001 06:44 PM
