HElP drive ok for few miles rpm drops cars turn off wait a few min and starts normaly
Old Feb 5, 2011
JackPr's Avatar
JackPr is an unknown quantity at this point
can someone help me! I was driving the other day when my civic lx 01 rpm just drop and i couldt accelerate past 20 mph when i pressed the brake my car would just turn off took it to a repair shop said the catalyct was clog took it out installed a header on it drives ok for a few miles but does the same tock it to scan and it says the o2 is bad and the tdc sensor could this be it plz help me. it drive ecellent for a few miles no traffic or for half an hour but after that the rpm just drop its stop i wait 10 mi and the car just drive fine till it does the same any ideas plzzzzz
THX IN ADVANCE
jack
Old Feb 5, 2011
Re: HElP drive ok for few miles rpm drops cars turn off wait a few min and starts nor
clogged IAC valve (idle air valve on the throttle body with coolant lines going to it) will cause stalling too
Old Feb 7, 2011
rhymeboy89's Avatar
rhymeboy89 is an unknown quantity at this point
first step is to always fix check engine light. If it is on there is a problem
Old Feb 9, 2011
floyd107's Avatar
floyd107 is on a distinguished road
i just had that exact problem like two days ago i changed the (cam position sen) part#su5583 and it was $51.99 and my car has been fine since if but to put it in you will need to remove you valve cover just enough to get your timming belt cover off and youll see the sensor in side there. its like the only thing with wires and rubber boot going through your timming belt cover. if you need pics just ask and ill show you were everything is
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blaster30
Apr 22, 2015 12:21 PM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
01civicboi
Bolt-on Engine Performance
Nov 2, 2001 07:33 AM
