new here......got a A/C problem...it died
Old Jan 30, 2011
themadness's Avatar
themadness is an unknown quantity at this point
my wife's 02 civic's A/C killed over on the way home today. it was blowing fine then it quit. changing the levels and settings caused a little air to linger but now its done.........nothing. the defrost, recirculate, and A/C button lights work. the heat is not working either.
i have checked all the fuses under the hood and the dash. all of them are good. there are a few fuse/relays that i dont quite understand how to check in the under hood box. the large black ones and the really big metallic ones i have left alone since i am not that tech saavy.
i also read that it could be the blower motor but again, you guys would know better than i.
thanks in advance to those that may help me out!
Old Jan 30, 2011
Re: new here......got a A/C problem...it died
is air blowing out the vents?
Old Jan 30, 2011
themadness's Avatar
no....it did for a few minutes after it first had problems this morning. but it does nothing at all now.
Old Jan 31, 2011
CraigW's Avatar
You can look down in with the cabin filters out and see if the fan runs.
See if it runs for a second when 1st switched on.
If so...much info here on the subject.
Old Feb 1, 2011
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Will the blower run on high?
If the transistor is bad the blower will only run on high.
Nathan
Old Feb 5, 2011
themadness's Avatar
Nathan
nah, it doesnt do anything. however, when we are going down the street a trickle of air will come out. if you turn on the recirc it stops. we went down interstate 95 last night and it was cold and rainy. at around 60 mph there was just enough air coming through the defrost vents to clear the windshield a 1/4 of the way up. but the air coming out if BARELY noticeable. i am going to pick up a relay from auto zone. its only about 10 bucks. worst case scenario, it doesnt work and i can return it.
i tested the transistor, as well as the transistor and blower motor connectors. both gave me an ohms reading when i tested them with a multi meter.
this is such a pain in the
Old Feb 5, 2011
that small amount of air is just natural wind blowing thru the ducts from outside when you are moving fast. has nothing to do with the electric part. did you check the blower motor relay?
Old Feb 5, 2011
themadness's Avatar
i'm going to take a stab in the dark and pick one up today. they are only 10 bucks and i can return it if need be. other than that i am stumped. resistor seems to be good. the blower motor never made any noise or give a warning it was going bad so i am going on the assumption it is cool as well. other than that i am stumped.
Old Feb 6, 2011
themadness's Avatar
well i picked up a relay last night and returned it today. it wasnt the problem. i ordered a resistor while i was at auto zone since it was the best price i could find. hopefully my luck will get better.
is there a fuse i may have overlooked either under the hood or under the dash?
Old Jul 13, 2011
Seby05's Avatar
Seby05 has a spectacular aura aboutSeby05 has a spectacular aura aboutSeby05 has a spectacular aura about
Hey I have the same problem, my ac or heater doesn't work. i get no air through the air ducts, can anyone tell me what it could be?
Old Jul 14, 2011
CraigW's Avatar
Did you check to see if the fan runs for a very short bit when the switch is turned on ??
Old Jul 14, 2011
Seby05's Avatar
Yes, it actually turns for like 3 secs whenever I turn the car on or when I turn the ac/heater on for the first time while the car is running, but nothing comes through the ducts tho. Just the fans that sit on the radiator turn for that short period of time
Old Jul 15, 2011
CraigW's Avatar
The fan running for a short bit when 1st turned on has been mentioned by someone before. It turned out to be the transistor or the safety device on it (TCO) had opened.
The info is here and some links possibly, You can replace the transistor as a unit $35-45 (approx) or replace the open TCO.
Old Jul 15, 2011
Seby05's Avatar
Ok, where is the transistor located and what is the TCO, my bad, I'm not that knowledgeable when it comes to electrical stuff... or engine stuff for that matter lol. I'm just trying to get it done cheap and quick, it's my daily driver and it sucks during the day, it's so hot outside
Old Jul 15, 2011
Seby05's Avatar
Oh, my bad, I've just seen the other thread you posted on about this subject, so I know what the TCO does, but do you know how I should go about getting the transistor? Is there a part number for it, and can i get it from Auto-zone? Or do I have to get it from Honda? Thank you
Old Jul 15, 2011
CraigW's Avatar
http://www.hondapartsnow.com/genuine...0-S5A-942.html
Old Jul 16, 2011
Seby05's Avatar
Hey thanks for all the help man, I dunno what I would've done if you wouldn't have told me what it might be. Lol, actually I would've prolly spent a lot of money at some shop that would rip me off. Hey, one more thing tho, before I go and spend money on the shipping, I found a transistor at autozone also, and if I special order it at the store, they won't charge me anything bc it would be a store pick-up, but just wanted to double check to make sure it's the same part? Here's the link, they actually have 2 diff models
http://www.autozone.com/autozone/par...questid=168689
Old Jul 16, 2011
CraigW's Avatar
Shipping will offset savings online, you may have to pay full msrp... but I would get it from Honda. I hate 3rd party parts, and it's only $10-15 more for OEM.
Old Jul 16, 2011
Seby05's Avatar
K thanks, I will let you know how it went as soon as I get it in.
JMKendrick
Sep 16, 2015 06:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
NROD315
Sep 4, 2015 09:22 PM
WaryDriver
Aug 22, 2015 06:50 PM
ZILLA
Jul 5, 2015 05:24 PM
