01 civic ex automatic transmission failure?
Old Jul 1, 2011
henry.yu811's Avatar
henry.yu811 is an unknown quantity at this point
*I'm new to CivicForums
I have a 2001 Honda Civic EX Coupe and the transmission failed yesterday. The car has about 128k miles on it. I went to LA and back with no problems. About 1/4 a mile away from my house, the transmission failed. Luckily this wasn't on the freeway, otherwise I would've died. The problem is that when I press the gas pedal, the car doesn't go anywhere. My engine revs but it doesn't go anywhere. I never experienced any problems with the transmission for the entire time I had the car. It just stopped working all of a sudden. I'm not sure what's wrong. The person who towed my car said that it could be the transmission solenoid pack, transmission shaft, torque converter, or the transmission cable. My car turns on and goes into every gear but when I press the gas, it doesn't move, it just revs the engine. The car was working perfectly throughout the day until I came home. Does anyone know what might have gone wrong? This is my only transportation and I want to get it fixed asap. But I want to figure what's wrong first. Thank you!
Old Jul 8, 2011
Re: 01 civic ex automatic transmission failure?
check the engine light, it may tell you whats wrong. sometimes a bad TPS (throttle position sensor) on the throttle body can cause the feeling of a broken trans. could also be an engine problem. if the timing belt broke, the engine wouldnt make any power to move the car.
Old Jul 13, 2011
theman's Avatar
theman is an unknown quantity at this point
it happened to me last year , also have a 2k1 civic with 170k KM on it. all of a sudden at a stop it just will not move or reverse just engine revs, got it towed and it was the transmission. I had a reconditioned one swap for $1200 CAN the next day and back in business, did a research and 01-04 had common tranny issues which was fixed at 05 model, but too late already. good luck cheers
Old Jul 16, 2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
kinda like the remanufactured ATF dipstick. thanks for coming out with the fix for the 01-05's in 2006. lol.
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
Rinzlor
Apr 24, 2015 10:33 AM
alexkharden
Apr 23, 2015 07:13 PM
Richkid23
Apr 19, 2015 12:53 PM
