overspray on brake discs
Old Jan 29, 2011
jeffconnell12's Avatar
jeffconnell12 is an unknown quantity at this point
hey, i just painted my calipers and noticed about an inch of light overspray above and below the calipers on the disc, should i try and remove it with paint thinner etc. or will it just rub off as soon as i engage the brakes? thanks
Old Jan 29, 2011
MindBomber's Avatar
Live for the Twisties
Re: overspray on brake discs
Just be careful braking for a few minutes and the pads will grind it right off.
Old Jan 29, 2011
Kennykid2002's Avatar
Kenny the Ricer
I would clean it up with a rag and acetone, then spray the whole thing with brake cleaner
Even if the brake pads cleaned it up, there would be some paint debris stuck in ur brake pads
Old Jan 29, 2011
and it smells gross
Old Jan 29, 2011
mac25's Avatar
Dr Krieger of Modification
i just let the brakes grind it off mine. my front discs always rust in the rain, but after driving they're back to silver, i don't think you'd have any problem if you just let the brakes eat the paint.
Old Jan 29, 2011
MindBomber's Avatar
A tiny bit might be stuck to the pads, but it would burn right off after braking a couple times. Like mac said, rotors rust all the time and thats no issue.
Old Jan 29, 2011
Kenny the Ricer
Enamel is different from rust....
And if he used engine enamel, which is rated for 500 degrees, it might be harder to burn off, id rather have peace of mind that it wouldnt smear all over my rotors >.<
Old Jan 30, 2011
mac25's Avatar
it's not so much the heat as it is the friction that grinds paint off. it sounded like it was less then one layers worth of paint, im imagining he doesn't have a nice glossy coat over the brake serface, that would comprimise brake safety.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
hatch90
Sep 3, 2015 08:45 AM
