Seatbelt not locking very well...
Hey guys.
So Emma here is deciding to act up...
My driver's side seatbelt won't click normally.
I have to insert the buckle, and move it around for about half a minute before it finally clicks. Either that, or jamming usually works too.
Any ideas?
Any ideas?
Re: Seatbelt not locking very well...
yeah happened to me under warranty and they replaced the buckle. try spraying some lube in there like silicone. i still get that happening sometimes and i think its just a defective piece.
I dealt with this problem on my wifes 01 LX the other night finally.
I used the air compressor to blow out the crud from the latch at 130PSI.
The latching got a little better. I did it again many times with the latch pointed down into the seat to better evacuate the foreign material.
That helped some more.
The final touch was to spray a quick shot of Tri-Flow into the latch and repeatedly fasten the buckle about 50 times while wiping the excess lube with a rag.
The latch now works perfectly for the first time in the two years of owning the car!!!
Nathan
Nathan
Hmm interesting...
I played around with it the other day, and it works a bit better now...
I'll try spraying some WD40 or something in there to see if it helps...
fvckbg
Oct 20, 2016 07:37 PM
sesi
Oct 1, 2015 02:03 PM
frank_kleng
Sep 29, 2015 10:55 PM
Bruce2
Sep 27, 2015 08:45 PM
Wiggles
Sep 8, 2015 05:05 PM
