1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
4-1 or 4-2-1 header d16z6?
Old Dec 26, 2010
94civicd16z6's Avatar
The Boss ;D
94civicd16z6 is an unknown quantity at this point
Exclamation 4-1 or 4-2-1 header d16z6?
ok, so i have a flowmaster 60 series muffler, magnaflow high flow cat, both 2.25. i just need a header for my d16z6 now. should i get a 4-1 race header or a 4-2-1 header? i hear that the 4-1 has more power, but is it going to hurt the engine driving daily? should i just get the 4-2-1? dc sports im thinkin any other reasonably priced brands? whats on your car? 100% stock everything. intake i have but not installed. no engine mods at all.
Old Dec 26, 2010
TRIZ's Avatar
Re: 4-1 or 4-2-1 header d16z6?
I had a 4-2-1 on my D17... its designed to allow the exhaust to flow faster, so if you have mods that increase your power output significantly, get the 4-2-1, if your just rocking an intake, then just get a 4-1.
Old Jan 2, 2011
The Boss ;D
thanks triz. kinda wishin i would have more replies to this thread.. i need some help please! im rockin the stock d16z6 with an aftermarket cone air filter (i know like 25 hp right? haha got it for 10 bucks) until it blows, then i plan on probably a b18c1 swap. i've done some research and they say 2.25 inch exhaust is the best to go with for a non turbo d16. i might run duals, but i already have one muffler, and cat, both 2.25, just need some decent reasonably cheap headers to complete and hear it! also what should i get???? a one piece or two piece? 4-2-1 or 4-1? thank you
Old Jan 3, 2011
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
I got the 4-2-1 On my Z6. Works fine, I use a straight pipe, So I am sure it'll work fine on yours w/ Cat( No Harm To Engine). Mine has a 2.5'' exhaust(tubing) and a 4.5'' outlet.. I would go with a smaller outlet than 4.5 though. I have NO 4th or 5th gear power. all though my 0-130 MPH is great, Once I shift into 4th and 5th, Not enough back pressure too actually take the hell off. Id say you should be fine, I am sure your exhaust setup will work better than mine.
Old Jan 3, 2011
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
try 10hp tops lol. 2.25 is good for an n/a build. dude dont gsr swap that thing build a nasty single cammer jammer lol. get a 2 piece 4-2-1 it will allow less flow but will allow for proper back pressure. get some z6 exhaust valves and stick them in place of your intake ones. cam it......cam it.....toda, skunk2, crane any of the above are great. d17 crank, vitara rods with ferrera raised heads, y8 intake mani, ls throttle body, prelude injectors, and any bolt ons you wish to add, that would make a wicked nasty n/a sohc right there, on a very reasonable budget.
Old Jan 5, 2011
The Boss ;D
thanks guys for all the advice. ok so after hearing your thoughts and some more research i think this header is the one i will go with. address: http://redline9.com/i-130001.aspx i hear megan is a decent brand, stainless steel, 4-2-1: 2 piece, and on sale. thanks again.
Old Feb 16, 2011
jwendt2003's Avatar
jwendt2003 is an unknown quantity at this point
Can you elaborate a little about modding a D16 without having to use turbo? It's all Japanese to me at this point, but I'm really interested. Thanks, Jim
Old Feb 16, 2011
"goose"Jay's Avatar
what would you like to know? or what are you trying to accomplish would be a better question?
Old Feb 17, 2011
jwendt2003's Avatar
Higher performance without spending for a turbo kit. I've heard about the cam kits; does that increase power the high or low end range? I've never heard of using exhaust valves on the intake or using prelude injectors. Also, is the y8 manifold a step up from the one I have now? I have a SOHC VTEC now, but I can't hear/feel it even kick in.
Old Feb 17, 2011
The Boss ;D
from what i've heard, the y8 manifold is a little better than the stock one. but i just bought a 4-2-1 two piece header for my d16, megan racing i found for like $175 online w/ shipping. i think the aftermarket header will give me a little more than the stock y8 manifold. sadly, our pull when vtec engages in our sohc is nothing near a dohc, and not the same "nos" sound. personally, i'm going to put headers, air intake, full 2.25" exhaust, high flow cat and muffler, and run it till she blows.. THEN get a dohc like a b series and soup the hell out of it. just a little work to the sohc to make it a little faster until i swap..
Old Feb 17, 2011
"goose"Jay's Avatar
ok the y8 is a sohc vtec motor first off, but the mani is shorter and plenium on it is fatter....I.E. more air flow. Prelude injectors are a higher cc rating than the stock d series, and are ideal for an N/A build because you can push more fuel with more air to keep the A/F ratio in spec and also allow for more power. Cams will allow for more high end than low, your low end is all in how your block is build for the most part. If you want to make more torgue go with a smaller cylinder wall and piston, d15b7 or d15b2 and put your vtec head on it. with the b7 block you can also use a d17 crank with allows for more hp and tq output. Does require a bit of machining for the rods though i do believe.
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Dave Brabant
20
Oct 6, 2015 12:44 AM
anubis62
Sep 27, 2015 12:56 AM
