8th Gen 2006 - 2011.
New to me 2007 Civic
Old Dec 24, 2010
Old Car Nut's Avatar
Old Car Nut is an unknown quantity at this point
Just purchased a 2007 Civic LX in Fiji Pearl Blue with 59,xxx miles that will become my daughter's car when she gets her license in late February.
It's a great vehicle, and we've gotten as high as 38 MPG driving between 65-80 MPH with the A/C on and in the pouring rain, and right at 30 MPG in the city. It's tight and solid with no interior rattles, and it tracks straight and brakes solidly.
The powertrain warranty is about to run out in the next couple of hundred miles, and there seems to be a clunk when shifting from park into reverse when the engine is cold. There's also sometimes a bit more vibration when it's in gear (5-speed automatic) and stopped than at other times. Also, getting on and off the gas when it's in first gear or on the freeway with the torque converter locked up will also give a slight clunk. Is this a sign of the motor mounts being bad, and if so, are these covered by the 60,000 mile powertrain warranty? Is there anything else from a powertrain viewpoint that I should have a look at?
It also only came with one key. A local Honda dealer (not where we purchased the car) is offering to sell us a master key and a valet key, cut them both, and program it for around $150 total. Is that a good deal?
Happy holidays, and thanks for all your help.
Old Dec 27, 2010
Re: New to me 2007 Civic
not sure about the warranty, but it really sounds like the engine mounts (59k... should be close to mine 01, so 7th gen, but similar?)? Mine were serviced at 75k, but that depends on road conditions).
The keys sound right price
Old Dec 27, 2010
Kennykid2002's Avatar
Kenny the Ricer
The key should be right price
Not sure if mounts are covered by powertrain tho...I'd have to ask around
Old Dec 28, 2010
Thanks. The Civic is at the dealer and they confirmed that if it is the engine mounts, it is covered by the 5 year/60k warranty. There are currently 59,908 miles on it.
Two other things catch my eye. First is that the intermittent wipers are irregularly intermittent. Sometimes, it'll wipe twice in a row, sometimes as many as five or six times in a row. Sometimes, it'll park partway up the windows between wipes. I thought I saw a TSB about that, but can't seem to find it now. Also, both rear wheels have a fair amount of negative camber. The right rear has a bit more negative than the left rear. It's not to the point where handling is affected. I also thought I saw a TSB about the upper control arms potentially being replaced to correct this but also can't seem to find that TSB now.
Can someone point me to these TSBs, or was I just imagining them?
Old Dec 28, 2010
Mad Dog Tannen's Avatar
The wiper motor might be going bad. Can you hear the wiper motor turning after the wiper stops moving?
Alignment should fix the camber issue. You may need new shocks/springs if those are sagging.
Old Dec 28, 2010
TRIZ's Avatar
My buddy had the same clunking of the auto tranny-- the cheaper fix would be the torque converter, the more expensive fix is pulling the tranny apart and finding the issue, which in my buddies case was the automatic trannys equivalent of a clutch.
Go get it checked out asap... my buddy is throwing 3-4k down for a complete rebuild (and to have the tranny beefed up to handle his high boost supercharger)
Old Dec 29, 2010
The dealer says the motor mounts are fine, and offered me a drive in another used Civic which did the same thing. They also did a complimentary inspection like they would do for any used vehicle they sell and everything checks out fine, but I guess they didn't check the wipers! No, the wiper motor doesn't continue to operate after the blades stop. It just doesn't do a single wipe all the time, and sometimes parks a couple of inches above its normal position.
The tires are good for another year or two, and are wearing normally so I'll do an alignment when these get replaced. Until then, it should be ready to go. The dealership says the suspension checks out fine and as I said before, it drives and handles fine, though I haven't really driven it hard. This car is for my daughter, who is a new driver and won't be pushing it hard either.
Thanks for everyone's help.
Old Dec 29, 2010
I am not sure about the wipers if the motor stops all together. It's probably not getting power. I am just guessing that it might be the switch or maybe a relay. I would look at the wiring diagram and test each component and the wiring associated with the wipers.
Old Dec 29, 2010
Mad Dog, the motor stops after it completes the wipes. I don't hear the wiper motor continue to run after the blades stop. It's just that sometimes it wipes more than once (sometimes four or five times in a row) before stopping, and sometimes when it stops, the wiper has just started moving upward to start another swipe, so that when the blade stops, the wiper is about an inch higher than where it normally parks.
I'll take a look to see what controls the intermittent feature. Seems like it should be a plug and replace fix, at least I hope so. Thanks.
Old Dec 30, 2010
I had the same problem on my 89 Bronco and it was the wiper motor.
Old Dec 31, 2010
Mad Dog, that's not good news. Anyway, it's now cold and sunny for the next week so I'll see if I can find the time to diagnose this.
Off topic, but the Civic is incredibly good on gas. Commuting in heavy traffic with sub-freezing temps still gives around 30 MPG, and around 40 MPG on straight freeway runs at 70+ MPH. Nice!
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
