1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
clutch interlock plastic piece
Old Dec 23, 2010
paarlberg's Avatar
paarlberg is an unknown quantity at this point
The little plastic piece on on the clutch pedal that allows it to hit the interlock switch finally fell out. How do I replace this? I can't tell if I need to drop the clutch pedal assembly, or if I need to get smaller hands .
It is a very tight fit at the top of the pedal, so I wasn't sure what needed to be removed to access the location.
This is a 93 Civic DX HB
Any suggestions?
Thanks
Old Dec 28, 2010
paarlberg's Avatar
Re: clutch interlock plastic piece
I looked at this again this weekend, I still can't see how to get it installed due to the u shaped bracket that hangs down being in the way.
Old Dec 28, 2010
bluhonda's Avatar
bluhonda is an unknown quantity at this point
I got you nop problem.
If you look up the pedals from under the dash,you would see the switches on a bracket. On the pedal there would be a small brcket that holds a rubber stopper.
If the stopper is bad, you would only see a bracket with a small hole. The switch pin is supposed to pushed by the stopper.
When the pedals are released, the stopper should have minimal clearance between the switch.
CLUTCH PEDAL, CLUTCH PEDAL POSITION SWITCH, AND CLUTCH INTERLOCK SWITCH ADJUSTMENT
NOTE:
Remove the driver's side floor mat before adjusting the clutch pedal.
The clutch is self-adjusting to compensate for wear.
If there is no clearance between the master cylinder piston and pushrod, the release bearing will be held against the diaphragm spring, which can result in clutch slippage or other clutch problems.
1 . Loosen locknut (A), and back off the clutch pedal position switch (B) (or adjusting bolt)
until it no longer touches the clutch pedal (C).
2 . Loosen locknut (D), and turn the pushrod (E) in or out to get the specified height (F) and stroke (G) at the clutch pedal.
3 . Clutch Pedal Stroke: 130 - 140 mm (5.1 - 5.5 in.)
Clutch Pedal Height: 198 mm (7.8 in.)
Tighten locknut (D).
4 . With the clutch pedal released, turn in the clutch pedal position switch (B) until it contacts the clutch pedal (C).
5 . Turn in the clutch pedal position switch (B) an additional 3/4 to 1 turn.
6 . Tighten locknut (A).
7 . Loosen locknut (H) and the clutch interlock switch (I).
8 . Press the clutch pedal to the floor.
9 . Release the clutch pedal 15 -20 mm (0.59 - 0.79 in.) from the fully pressed position, and hold
it there. Adjust the position of the clutch interlock switch (I) so the engine will start with the
clutch pedal in this position.
10 . Tighten locknut (H).
Old Dec 28, 2010
paarlberg's Avatar
Thanks..
The piece that I am missing is the upper plastic piece that hits "H" when the pedal is pressed. Not sure if this procedure will work or not.
Dakota21601
Aug 18, 2015 08:41 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Chatito
Aug 14, 2015 02:04 PM
gmiguel
Jul 30, 2015 10:52 AM
