HID harness...will this work for a 2002 Civic LX?
Old Dec 12, 2010
Seks's Avatar
Seks is an unknown quantity at this point
I am really sure the seller on ebay sent me the wrong ones:
My HID kit has hi/lo bulbs but I just wanna get the lo going. The hi is not important.
Old Dec 12, 2010
sl33pyriceboi's Avatar
Re: HID harness...will this work for a 2002 Civic LX?
it can work, but u will needa mod it.
but it doesn't look like its designed for the H4 system.
Old Dec 12, 2010
it looks like it might fit in the 2 vertical plugs on the h4 harness.. Too bad that would hook it up to the high beam instead of the low beam.
It may be too wide though.
Old Dec 13, 2010
Seks's Avatar
I guess I have to cut off the 2-prong connector and crimp a spade for each wire to make it work?
Old Dec 13, 2010
wont work. because the left is a positive and the right side is ground for the high beam.
use quick male/female disconnect. google what they are if u dont know.
Old Dec 13, 2010
Like I said, too bad it would hook it up to high beams instead of low beams.
Old Dec 13, 2010
Seks's Avatar
Well, what I meant is...
Can I not cut off the black connector, and crimp these on:
http://www.highoctanecaraccessories....minal_male.jpg
..then insert the spade for the red to the +12V and insert the soade for the black to the low beam ground?
Old Dec 13, 2010
I would rather cut and splice an H4 harness in, but that's just me.
http://cgi.ebay.com/ebaymotors/ws/eB...ht_1422wt_1165
Old Dec 13, 2010
yes. those are called "male/female quick disconnectors"
Old Jan 16, 2011
Seks's Avatar
Will this work?
http://cgi.ebay.com/ebaymotors/ws/eB...m=250705468044
Old Jan 17, 2011
electric130's Avatar
doubt it. looks to be for a positive switched H4, not ground switched like 7th gens. see how the H4 connector has 2 black wires on the high beam pin? they're using that ground somewhere else likely, assuming it's constant.
i was trying to sell my relay harness several months ago and noone wanted it. it had lows, highs, and fogs, all on relays with diode suppressors. i got tired of looking at it laying around so i cut the relays and dual relay bases off, kept those and tossed the wire.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
jonavin
73
Oct 4, 2004 07:18 PM
Lightman
15
Nov 8, 2001 05:06 PM
