Stiff/Squeaky Gear Shift
Old Dec 8, 2010
ZiaPilot's Avatar
ZiaPilot is an unknown quantity at this point
Question Stiff/Squeaky Gear Shift
I am having a problem with my 2001 EX coupe, the gear shift is suddenly much harder to shift, it feels very stiff and makes a creaking/squeaky noise when changing gears. I originally thought this might be due to the cold weather but even after warming up the problem persists. I have had no other previous problems with the transmission. I took it to a transmission shop but they want $500 just to inspect it. I hope it is just a simple lubrication issue. Any input?
Old Dec 8, 2010
lazlong's Avatar
Re: Stiff/Squeaky Gear Shift
http://www.hondapartscheap.com/south...t=0&quantity=0 Pull the center console off and you'll be looking at this (except for the front part, it's on the tranny. lol). Try greasing the pins, if they're worn replace them. If that doesn't work it's either the cable (#7) or the shifter (#1).
Old Dec 15, 2010
ZiaPilot's Avatar
Update: I removed the console as suggested, and used white lithium grease on the pins and cables. The main culprit appeared to be the shift "ball" which I greased as well. Thus far problem solved; the squeaking is completely gone and the car shifts like new. Thanks for your help!
Old Dec 15, 2010
TRIZ's Avatar
Which parts exactly did you grease that took away the problem?
Old Dec 22, 2010
ZiaPilot's Avatar
With the console removed, I greased the cables running to and from the shifter. What made the most difference was lubricating the plastic "ball" that the shift lever comes out of. It is actually separated into two parts and this part was causing the noise and stiff shifting. I used the lithium grease and ran the car through all the gears several times before reapplying. Two weeks later and it still shifts like new with no noise.
Old Dec 22, 2010
TRIZ's Avatar
I did the same thing 2 days ago- but I only pulled the console and greased the ball jamming a decent amount of grease in the crack of the ball and all around it. Also greased the pins that hold the shifter cables as well, but it wasnt needed. It was night and day. I think the shifter is better then it was when I first got my car used at 60k.
nirvanaguy
25
Oct 26, 2017 07:26 PM
Bricoleur
Sep 9, 2015 06:48 PM
Brad Andrew
Sep 8, 2015 08:25 PM
Brad Andrew
Sep 8, 2015 08:22 PM
tommycanada
Sep 5, 2015 04:59 PM
