8th Gen 2006 - 2011.
Honda car batteries = junk?
Old Nov 22, 2010
joegeek's Avatar
joegeek is an unknown quantity at this point
I need a new battery for my 07 EX and trying to decide between a Honda, Interstate, Everstart or something else. Can anyone give me some help deciding?
Old Nov 22, 2010
Re: Honda car batteries = junk?
honda = interstate if that helps. they are pretty decent batteries. if the newer civic still uses group51 size, honda sells a 500cca battery instead of the older 420. its a good upgrade.
Old Nov 22, 2010
MelJ's Avatar
Trance Addict
My old car had an Interstate. VERY reliable. Never gave me any issues. I mean none whatsoever. Started up on even the coldest days in February.
Old Nov 22, 2010
Paul79UF's Avatar
Paul79UF is an unknown quantity at this point
I always just buy the cheap DuraMaxx batteries at WalMart since they seem to last at least 4-5 years.
My last one only lasted 3.5 years since I let the car sit for a few months while I was out of the country. Died just a few months after the warranty ran out.
Old Nov 22, 2010
Kennykid2002's Avatar
Kenny the Ricer
My 03 honda stock battery lasted 7 years, was still running with enough juice to start the car, but it was low on CCA, so i topped it off with an ACDelco battery, runs great
If you don't mind 2x the cost of a regular battery, get an Optima yellow top, those last 10+ years (more than twice the lifespan of a regular battery), and is a deep cycle battery, so if one day you forget your headlights, and drain your batt, just jump it, charge it for a bit, and it will be back in top shape
Regular batteries lose holding capacity when drained a couple times
Old Nov 22, 2010
BlueEM2's Avatar
Whachya lookin at?
I have a Honda battery in right now that's over 5 years old and it still starts the car no problem. Pretty reliable.
Old Nov 22, 2010
my yellow top barely lasted 2 yrs. and it was always low on charge even after fully charging it. stick with proven lead-acid
Old Nov 22, 2010
Kenny the Ricer
Maybe you got a defective one o.o
Everyone i know that has a yellowtop is like 5years+ already
Still at 14.0~14.8V
Old Nov 22, 2010
BlueEM2's Avatar
Whachya lookin at?
Pretty expensive considering if you take care of a lead-acid it will last you 5+ years. Just don't leave your lights on.
Old Nov 22, 2010
i actually prefer the ones with removable caps. so you can check the levels and add water if needed.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
