1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1988 clutch install, can't get transaxle out...
Old Nov 6, 2010
bigredscowboy's Avatar
bigredscowboy is an unknown quantity at this point
Posting this for a friend, please forgive me if its vague for I've only worked on Ford Rangers.
Following the Haynes manual: removed bolts from bellhousing and gently pried it 1/2" from the block. No progress has been made since with firm prying and tilting of bellhousing. Is this common? Should enough pressure release the transaxle or has something not been removed properly?
ATH
Old Nov 9, 2010
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: 1988 clutch install, can't get transaxle out...
check to make sure the bolt on the back side on the bottom has been removed. Some tend to over look it.
Old Nov 9, 2010
530matt's Avatar
530matt is an unknown quantity at this point
rear trans mount needs to be removed aswell,
Adam925
Nov 19, 2019 10:56 AM
OptimisticWay
27
Jul 6, 2015 12:56 PM
OptimisticWay
May 12, 2015 01:30 PM
bsmiley
Apr 27, 2015 01:27 PM
meels808
Nov 20, 2001 09:37 AM
