1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Need some swap advice (D16z6 to D15b)
Old Nov 6, 2010
oxiclean's Avatar
oxiclean is an unknown quantity at this point
Current Car Specs:
92' Civic EX (pretty much stock)
D16z6 engine
Hi all,
Let me preface my question by explaining what happened. It came time to take my civic to DEQ for its Smog check. My car had been idling a bit roughly and I hadn't had time to check it. I guess something was really wrong because it failed miserably (HC was 10 times above what it should be). Anyway, long story short I took it to a shop and they said it was a burnt valve (cylinder pressure 180-180-50-160).
Rather than attempt to rebuild the engine I decided I want to take this opportunity to do my first engine swap. So I began researching and it turns out that my engine (D16z6) is kind of difficult to find. Then I came upon the following threads which seemed to answer some of the questions that I had:
http://www.honda-tech.com/showthread.php?t=2591488
http://www.d-series.org/forums/gener...-vtec-faq.html
So anyway the question I had was if I get the following motor, will the swap be pretty straight forward? Or are there any gotcha's that I should be aware of? Additionally, are their any reputable online businesses that sell engines that you can recommend. I have heard that h-motors online is pretty good.
http://cgi.ebay.com/ebaymotors/JDM-D...item3a60392f5e
Any help or advice is much appreciated.
Thanks!
Old Nov 10, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
Re: Need some swap advice (D16z6 to D15b)
dude all u have to do is have a vlave job done... its not a rebuild... its just head work and thats going to cheaper and if i was u i would stay with ur z6.... and if u still want to do the swap ago ahead... but if u do let me know ill buy ur z6 just so i can have a extra one.. : )
soufigured
15
Aug 18, 2015 08:22 PM
OldschoolCool
Aug 17, 2015 05:05 PM
JKWood
Jul 28, 2015 03:45 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
