Transmission won't engage....
Old Oct 27, 2010
sp103154's Avatar
sp103154 is an unknown quantity at this point
Here's the problem: Car starts fine, Clutch pedal feels and seem to be fine, transmission shifts to all gears with the clutch depressed as well as without the clutch but it will not engage, perpetual neutral? There are no noises, there have been no noises and seems to me that if the clutch disk was worn out the trans would not shift through all the gears?
This is a 5 speed manual, not an auto. Anyone has the solution?
Old Nov 13, 2010
Scrivyscriv's Avatar
Scrivyscriv is an unknown quantity at this point
Re: Transmission won't engage....
Can you change gears with the clutch released and engine running? Any history of problems or noises prior to now?
Old Nov 14, 2010
lazlong's Avatar
Sounds like a broken clutch cable/ link. If you have an hydraulic clutch check for leaks at the clutch master cylinder and slave cylinder. Start at the slave cylinder, that's usually the first to break.
The slave cylinder has a metal line going to it and is on the clutch casing. I have a 7th gen but, yours should look similar:
mattdoc
Mar 14, 2017 12:10 PM
Boostgst
Jun 29, 2015 11:38 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
bsmiley
Apr 27, 2015 01:27 PM
Richkid23
Apr 19, 2015 12:53 PM
