1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Mini me bogg
Old Oct 4, 2010
88WAG's Avatar
88WAG is an unknown quantity at this point
Mini me bogg
All, I am at a lose. I have a 88 Honda Wagovan and pulled the d15b2 and dropped in a d15bvtec. Runs good, but boggs when you give it gas. You can let off the throttle a little and give it gas and it will kick in. It also boggs when I try to hit vtec. I need the help of experts. Please help!!!!!
88WAG
Old Oct 4, 2010
02civicsi02's Avatar
Low and slow!
Re: Mini me bogg
Any codes? You might want to check the spark plugs, plug wires, distributor cap/rotor, injectors, fuel filter.
Old Oct 5, 2010
88WAG's Avatar
Re: Mini me bogg
No codes found, I will check out your suggestions. I will let you know what I find. Thanks for your time. Have a blessed day.
88WAG
i
Old Oct 9, 2010
88WAG's Avatar
Re: Mini me bogg
Tried your suggestions, but no luck. I may have not been accurate. It boggs at idle when you go full throttle. It boggs and surges, boggs and surges. If we pinch off the vacuum hose on the fuel reg on the the fuel rail. It will pick up and run. I even tried another P28, no change.
Dave Brabant
Sep 27, 2015 09:43 PM
h4ldol
Sep 17, 2015 01:25 PM
