1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
no spark, need help fast!!
Old Oct 4, 2010
1991civichbsi's Avatar
1991civichbsi is an unknown quantity at this point
Lightbulb no spark, need help fast!!
Let's put on our thinking caps.....
1991 civic hb si
1.5L
stock w/ 196,000
Alright friends,
Car was has been running fine up til just a bit ago. pulled it into the garage to change the carpet out, everything went fine, until i tried to start it....won't start. It cranks over, but will not fire. No spark!!!
Now about two months ago i changed out the head gasket, water pump, timing belt, dist. cap and rotor, plugs, and wires. Gave it the usual tune up. Everything running fine, a little sluggish and my gas mileage went down quite a bit, so kinda chalked it up to my timing. Was getting to that, then the car just stopped firing. Pulled the plugs, and they do seem to be fouled by oil, but would that stop the spark from shooting down the wires?
It seems like i looked at everything that might be a suspect. Changed out the coil, had the ignitor tested..good. Main relay seems to be working...clicks three times when in the different key spots, fuel pump primes, check engine light comes on for a few then goes out....so seems like everything is good. no blown fuses... so i'm totoally lost now.
Hopefully you guys can help me out with some suggestions. Any would be appreciated. Need to get it fired up asap. My only mode of transportation.
Thanks a million
Old Oct 4, 2010
95EX's Avatar
95EX is an unknown quantity at this point
Re: no spark, need help fast!!
you asked about fouled plugs...by all means this would not let the car run. clean them really good and try.
Just to cover all aspects take off the dist. cover and crank it to make sure the dist. is turning. check the contacts inside and make sure they arent burnt.
Old Oct 4, 2010
Angry Re: no spark, need help fast!!
dist. is turning. still nothing. cleaned plugs. but nothing. just going back to the beginning. anything is possible, but with all the test ive been running and everything checking out, is it possible that the cap is bad along with wires? it would be my luck that something simple like this would be the problem. i guess i will just go buy new ones and see if that is the problem. if so, i'm boycotting autozone for selling crap!
Old Oct 4, 2010
95EX's Avatar
take out the plugs and crank to see if theres spark....
if so then 1 of 3 things is good
check from the filter to the TB and check for obstructions or anything...
if nothing then 2 of 3 things is good
only thing left is fuel
did you touch any fuel parts? have yoy changed the filter lately? maybe the pump took a dump?
Old Oct 7, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
check ur ecu....
Old Oct 8, 2010
Talking Re: no spark, need help fast!!
thanks for your guy's advice. checked everything you suggested, and it ended up being a bad main relay. everything seemed to be working when i checked it the first time, cel light, pump, the clicking noises. but i decided to resolder it anyway, and it fired up first shot. reset my timing, was off just a bit, and shazam, it's running again. thanks for everything.
SimpleUser
Apr 24, 2021 02:54 AM
Rlss
24
Feb 26, 2016 09:42 PM
jonwalden68
Aug 27, 2015 12:07 PM
DubbleChrisP
Aug 19, 2015 12:37 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
