Up down Up down
Old Sep 6, 2010
AllDarkCiv's Avatar
AllDarkCiv has a little shameless behaviour in the past
Up down Up down
I have a 96 civic ex and i have a fluctuating warm idle. I've put on a brand new idle control valve, throttle body gasket, 02 sensors, and my computer is working fine it seems. I have bled the coolant and checked for air leaks. Anyone have any guesses to why im still having this problem? It only happens sometimes when the car is warm like it has to find the idle for a minute then it settles. car drives fine.
Old Sep 6, 2010
Mad Dog Tannen's Avatar
Re: Up down Up down
Could be a vacuum leak somewhere, bad TPS, clogged injectors. I would run fuel injector cleaner and check all vacuum hoses first. When was the last time you changed the fuel filter?
Old Sep 6, 2010
AllDarkCiv's Avatar
Re: Up down Up down
Yeah i really wanna check all the vacuum hoses. Can you name me all the places that would affect idle from these? could it be from anywhere? or just the throttle body area hoses? I have a new pcv valve , fuel filter, and spark plugs too, i forgot to add.
Old Sep 6, 2010
Re: Up down Up down
Make sure your PCV valve is properly hooked up to your intake that could create vacuum leak. Make sure all plug wires are on good. Did you gap the plugs properly? Just look at all of the hoses coming off of your intake and make sure they are all attached to something and are not worn/deteriorated/cracked. Give em a little tug and see if anything is falling apart or coming off. A good inspection should always be the first step. Run some fuel injector cleaner additive that's good to do every once in a while anyway.
Old Sep 6, 2010
AllDarkCiv's Avatar
Re: Up down Up down
Fuel injector cleaner does nothing. This problem is not fuel related. All my hoses look new still. No cracks, no wear, still clean . Car is very well maintained by me. Nothings been tampered with that i wasn't confident i could do. Could a random up down idle that fixes itself after several restarts be computer or ignition related? The car starts and has always started well... What i wanna know is why starting it a few more times makes it go away eventually? and if its an air leak wouldnt it be consistent? Please answer these questions.
Old Sep 6, 2010
Re: Up down Up down
Is your timing good?
I cannot tell if you are saying that fuel injector cleaner does not clean injectors. Or that you tried it and it didn't work. But if you think it doesn't do what it is supposed to then you are wrong. I used it on my bronco and it fixed a problem that sounds exactly the same as what you are experiencing.
Old Sep 7, 2010
AllDarkCiv's Avatar
Re: Up down Up down
Bump, for real help to actually answer my questions, not share personal experiences unrelated and argue.
Injectors dont cause a fluctuating idle, maybe an air leak in one could, but thats been ruled out in my injectors and throttle body, and fuel injector is not strong enough to clean a real injector clogging, not to mention most injectors dont get clogged unless a vehicle is not taken care of , in which case i stated mine was , if you had read it.
What i wanna know is why starting it a few more times makes it go away eventually? and if its an air leak wouldnt it be consistent? Please SOMEONE ELSE answer these questions.
Old Sep 7, 2010
Re: Up down Up down
Ok, you are a douche. That is real advice, that is completely related to the topic. I am sorry that I said you were wrong, but grow some thicker skin. Some cars just need fuel injector cleaner every once in a while no matter how well maintained.
If you know so much, then why haven't you fixed it already? Why even ask for advice on a forum?
It sounds like you blindly threw a bunch of parts at the problem and wasted your time and money. Have fun guessing some more! lol
Old Sep 7, 2010
lazlong's Avatar
Re: Up down Up down
Ethanol gums up any engine.
It sounds like it may be an EVAP system problem. Try changing EVAP canister.
Old Sep 7, 2010
AllDarkCiv's Avatar
Re: Up down Up down
Evap canister is something new i havent heard. Thanks. Gonna check that. I better also pour fuel injector cleaner into the evap too ! lulz.
Hey mad dog, you tough internet hero. What i did was a basic tune up. Ever heard of that? Did i mention an engine swap to fix an idle problem? Na. but you mentioned fuel injector cleaner haha. You're telling me to run fuel injector cleaner to fix an idle problem and calling me a "douche" and trying to bash me for doing a general tune up on my car. I noticed you post on EVERYONES posts with lame attempts at information to problems just to try to rack up lots of posts here. I know you're offended and angry that not everyone in life is going to believe your dim witted information, but i'd be very shocked to hear that YOU actually know what YOU'RE doing. You tell everyone here on the forum to use injector cleaner or change their injectors. Its called diagnostics. And your only means of diagnostics is fuel injector cleaner. SO i think the real "lol" is on you moron. Please stop arguing with me. Your so blinded by your own ego and supposed cosmic significance that you think you're right HANDS DOWN. Trying to offend someone by telling them they threw parts at a car? some people happen to love their cars and buy new parts because they like performance as well. You took some retarded guesses, got offended, and then typed "lol" You're a real gem of knowledge aren't you. Grow up loser. Make sure you type lots more trying to pretend you have some pearls of wisdom to share. I wont be listening.
Old Sep 7, 2010
Re: Up down Up down
be nice...
i too get too angry sometimes and say things i do not mean. not sure about your background, so not going to bother you about it.
just chill down. just my 2 cents.
Old Sep 7, 2010
02civicsi02's Avatar
Low and slow!
Re: Up down Up down
There are many things that can make the idle fluctuate even something with fuel related. You came on here wanting advice about this and people gave you some and you had to get up his *** that its not fuel related but someone says that it could be the evap system. The evap system is fuel related if you kno anything.
Since you have done alot of things and have done the usual tune up. The thing that is left is the TBS, vacumm leaks, fuel injectors, or it could be the evap system like said above. And fuel injectors could be it even if you say it cant. If the engine is not getting enough fuel the engine could rev itself to give it more air and fuel to keep it running.
Old Sep 7, 2010
AllDarkCiv's Avatar
Re: Up down Up down
I asked a simple question about air leaks being possible to be intermittent or if they ALWAYS would have the same effect throughout daily operation? If an idle only fluctuates sometimes (rarely), would this still be considered a possible air leak? wouldn't an air leak always show itself? Thats all i need to know. Thanks.
Old Sep 7, 2010
AllDarkCiv's Avatar
Re: Up down Up down
all basic checks have been done. I've used fuel injector cleaners in the past...didnt fix it... i have checked the sensors ranges...all in range... coolant bled....lots of stuff. just looking for a new place to try. injectors have been pulled out and cleaned through mr injector..pro service.. this is why i jumped away from that aspect. i'd rather discuss the problem than try to explain my supposed errors.
Old Sep 7, 2010
Low and slow!
Re: Up down Up down
You could have cleaned them but there is still the fact that one of the injectors can not be working and opening fully just saying. And with a vacuum leak it can go both ways. The leak will always be there leaking at all times but it could cause the idle to bounce and also it could have the idle always up at a constant place.
Old Sep 7, 2010
Re: Up down Up down
Wow. I am very flattered that you were so touched, that you took the time to look at some of my other posts. You just keep on believing that you know what your doing. Keep throwing those parts at it. You definately could have said that you had already cleaned the injectors and we could have ruled that out. I was simply asking questions to try to isolate the problem. I have fixed more jets and cars then you have looked at. By the way why would anyone want to make there post count go up? Do you get a prize or something? You'll be happy to know that you will get no more advice from me.
Have a lovely day sweetie!
Old Sep 8, 2010
AllDarkCiv's Avatar
Re: Up down Up down
"You just keep on believing that you know what your doing"
"By the way why would anyone want to make there post count go up? "
Yeah and keep thinking you can type a sentence without misspelling the most basic of words.
lulz @ jets. Ok cool guy. You're better. We know.
Mad dog the ase certified basement tech.
Cant seem to go anywhere on the forum without seeing your posts clogging everything up. You poor scrawny little twit.Your pictures are laughable of your self. You must feel elite over there.
Now you're projecting your own feelings onto the screen about winning a prize. Since you're the one LIVING on the site here its safe to say that you cant come to grips with your own reasoning's. A sure sign of low self esteem.
"Have a lovely day sweetie!" MEN and their orifices, what mad dog knows best.
Old Sep 8, 2010
Low and slow!
Re: Up down Up down
Ok calm down both of you. There is no need for any bickering here.
Old Sep 8, 2010
Re: Up down Up down
All Dark: Congratulations you can make **** up! The only real thing you can say about me is that I mispelled words. Good job.
You never answered my question. What do I get for posting so much? I cannot wait to find out!
You are right I've never been ASE certified. Cars and bikes are just my hobby and Jets are my job. I guess you would know more about cars with your ASE certification. That's why you already have your idle problem fixed.
P.S. Acronyms are usually capitalized
Old Sep 8, 2010
Re: Up down Up down
will both of you just calm down? it's not worth it, really...
Old Sep 8, 2010
Re: Up down Up down
be nice... we do not need this here... I could not even quote your words!
