1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94 Civic Randomly Stalling then not starting
Old Sep 4, 2010
dwills898's Avatar
dwills898 is an unknown quantity at this point
Hi,
My 94 honda civic started stalling this summer. Sometimes I can drive it for an half an hour on the freeway at 70 and nothing happens. Then other times after I have been driving for a half an hour or so, I will start losing power and it tries to stall and sometimes actually stalls. After it stalls it wont start back up again. If I let it sit for 15 minutes then it will start back up again and I can drive it.
If I let it sit in the driveway and heat it up (I have no fan installed), sometimes it will stall, and then when I try to restart it, it wont start up.
I put a blow dryer on the main relay and heated it up and I couldnt get it to not start or stall, so I think I have eliminated the main relay, (I can hear three click plus the fuel pump turning on and running) Also during the times that it wont start up, I can hear the fuel pump coming on.
I replaced the fuel pressure regulator with my brothers and it still stalled so I am assuming that is not it....
Anybody have any suggestions?
Thanks
Don
Old Sep 5, 2010
lazlong's Avatar
Re: 94 Civic Randomly Stalling then not starting
Check ignition system for spark and look for loose connections/broken wires.
Old Sep 5, 2010
kitchenguy's Avatar
kitchenguy is an unknown quantity at this point
Hi there,
I have a post here(89 civic LX problem) which problem sounds similar to yours. Take a look at the post and see if the symptoms listed sound familiar. No one here has responded with a plausable solution yet. When our car doesn't start there is spark and a strong odor of fuel from the exaust. As the engine is turning over it appears to be coughing every vew revolutions or so.I believe a flooding condition for what ever reason developes when the car will not start, then after the car is alowed to rest for a while the flooded condition subsides and the car then starts.
Old Sep 5, 2010
Civvyftw11's Avatar
Civvyftw11 is an unknown quantity at this point
Check the ecu for codes.
Old Sep 5, 2010
dwills898's Avatar
There arent any codes....I think I may have fixed it, I let it idle for 45 minutes today and it hasnt stalled yet....I pulled the ignition switch out and cleaned it, it was dirty and the connections were kind of corroded so I sanded them down and cleaned it all out....so far I think that was it, I will see if it stalls later in the week when I drive it. This was AFTER i switched my brothers fuel pump and main relay into my car and both did not fix it.
Old Oct 9, 2010
dwills898's Avatar
Well that totally did not fix it, it was still stalling after I cleaned the ignition switch.....BUT what did fix it was replacing the ignition control module. I just replaced it and now it does not stall anymore. so for future reference for anyone that has this problem, my car would drive for about 45 minutes and then stall and not start up for like 10 minutes.
rcolosi
Apr 29, 2015 07:48 PM
McD
Apr 29, 2015 03:50 PM
Blaster30
Apr 22, 2015 12:21 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
CivicVoz
Apr 16, 2015 08:07 PM
