Likely input shaft bearing... with video! 2005 Civic.
Old Aug 24, 2010
dmidd's Avatar
dmidd is an unknown quantity at this point
Angry Likely input shaft bearing... with video! 2005 Civic.
From what I've read, I have a bad or going bad ISB. I recorded it to see if you guys think that's the case:
http://www.youtube.com/watch?v=XOR4CiYJ2sw
Ideas?
Thanks
Old Aug 24, 2010
ubnpast's Avatar
ubnpast is on a distinguished road
Re: Likely input shaft bearing... with video! 2005 Civic.
How many miles?, I would say tob. Could be wrong, see what others say.
Old Aug 24, 2010
dmidd's Avatar
Creeping up on 67000.
Old Aug 27, 2010
dmidd's Avatar
bump
Old Aug 27, 2010
j00fek's Avatar
j00fek is an unknown quantity at this point
i have the same thing, 188k
ill be tearing out the tranny in the spring to do an overhaul
Old Aug 27, 2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
I just watched this on my phone. And I think I have the exact same issue after completing my timing belt/drive belts/water pump.
Is the sound like a loose bearing (like something is loose), and during idle? The sound comes and goes?
I spent another 12 hrs trying to determine if it were my drive belts but the noise is coming from the bottom (deceivingly towards the front by the P/S belt & A/C belt area).
Is this the case of a bad bearing? And if so, just how hard is it to fix? ****, I don't want to spend any more time & money trying to fix this...dammit!
Old Aug 28, 2010
j00fek's Avatar
Nosepicker, call your local tranny place and see how much they would quote a main shaft bearing replacement, or overhaul since to get there you pretty much need to over haul the tranny
Reverb2005
Jun 26, 2015 06:22 PM
wholt0
Transmission
Jun 11, 2015 11:15 PM
begogadashi
Jun 11, 2015 04:04 AM
MajTom
Jun 2, 2015 11:48 AM
dosmastr
May 5, 2015 12:19 PM
