Likely input shaft bearing... with video! 2005 Civic.
Old 08-24-2010
dmidd's Avatar
dmidd is an unknown quantity at this point
Angry Likely input shaft bearing... with video! 2005 Civic.
From what I've read, I have a bad or going bad ISB. I recorded it to see if you guys think that's the case:
http://www.youtube.com/watch?v=XOR4CiYJ2sw
Ideas?
Thanks
Old 08-24-2010
ubnpast's Avatar
ubnpast is on a distinguished road
Re: Likely input shaft bearing... with video! 2005 Civic.
How many miles?, I would say tob. Could be wrong, see what others say.
Old 08-24-2010
dmidd's Avatar
Creeping up on 67000.
Old 08-27-2010
dmidd's Avatar
bump
Old 08-27-2010
j00fek's Avatar
j00fek is an unknown quantity at this point
i have the same thing, 188k
ill be tearing out the tranny in the spring to do an overhaul
Old 08-27-2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
I just watched this on my phone. And I think I have the exact same issue after completing my timing belt/drive belts/water pump.
Is the sound like a loose bearing (like something is loose), and during idle? The sound comes and goes?
I spent another 12 hrs trying to determine if it were my drive belts but the noise is coming from the bottom (deceivingly towards the front by the P/S belt & A/C belt area).
Is this the case of a bad bearing? And if so, just how hard is it to fix? ****, I don't want to spend any more time & money trying to fix this...dammit!
Old 08-28-2010
j00fek's Avatar
Nosepicker, call your local tranny place and see how much they would quote a main shaft bearing replacement, or overhaul since to get there you pretty much need to over haul the tranny
Reverb2005
06-26-2015 06:22 PM
wholt0
Transmission
06-11-2015 11:15 PM
begogadashi
06-11-2015 04:04 AM
MajTom
06-02-2015 11:48 AM
dosmastr
05-05-2015 12:19 PM
Quick Reply: Likely input shaft bearing... with video! 2005 Civic.
