control arm bushings
Old Jul 17, 2010
skalin's Avatar
skalin is an unknown quantity at this point
I have a 2001 Civic with 36K miles. Dealer says my bushings are cracked. Is this a serious problem?
Old Jul 17, 2010
Re: control arm bushings
yeah its pretty serious. affects hi speed cornering, can throw off alignment and cause excessive tire wear, it can eventually lead to major problems because those bushings are very weak and can fail at any time. most of us here switch to the ES (energy suspension) poly bushings which are a lifetime part. the bushing is thicker and will not degrade like rubber, but it does tend to make some squeaky sounds in the winter going over bumps. in warm weather, not a sound.
Old Jul 19, 2010
Jordon112's Avatar
Jordon112 is an unknown quantity at this point
I'm in the same boat. Mine are worn out on my 2001; I can hear the clunking sound when I'm driving. The parts store was selling the Delco brand for 13-15$. That's not too bad. Its the labour that will cost you, unfortunately.
My two questions are:
1) I was told that I should purchase a sway link kit when replacing the LCA bushing. Do you guys think it's necessary?
2) Also, would an alignment be necessary?
I'm getting quotes in the $300 range which seems high for just changing the bushing :S.
Old Jul 19, 2010
lazlong's Avatar
Those bushings are press fit = labor intensive=$. Lots of flag hours for press fit bushings.
Get links. They help a lot with stability and they could save your life in an emergency maneuver.
An alignment is necessary. Once you take all that stuff apart it is impossible to get it back to where it was without an alignment machine.
Old Jul 22, 2010
link kit is only needed if the factory links are broken. sears installed all 4 lca bushings for $150 i believe. im not recommending them, cause you never know what kind of job they do, but i knew most of the techs there at the time.
Old Jul 29, 2010
Jordon112's Avatar
I went with the honda bushings which were 16$ a piece. I replace the two front lower control arm bushing. The total bill = 200$. The old bushing were completely shot with little rubber left lol. Unfortunately though I still hear a ka-ching ka-ching sound from both front sides of the car when I first begin to drive it in the morning....its so frustrating!!! :S
Old Jul 29, 2010
lazlong's Avatar
Could be strut mounts.
Old Jul 30, 2010
ashokudu's Avatar
ashokudu is an unknown quantity at this point
I changed these bushings on my car by myself, and lord is it a pain. They are press-fit and needs special tooling so you do not damage it while press-fitting it. I had to warm my LCA so the bushings would go in smooth. I put OEM bushings.
Things to watch out for. Careful on damaging the dust boot on the lower ball joint, if you plan to do it yourself. One more thing, the bolts tend to be rusted out and I did not have big enough impact wrench so I had to cut them...scary. And you do need alignment done once you replace these.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
brainwashedmc
Jul 27, 2015 10:05 PM
muttleytm
Jul 14, 2015 05:31 PM
fordover
Jul 11, 2015 09:10 PM
