2000 Civic Spedometer goes to 20mph when car is on
Old Jul 12, 2010
TJMike's Avatar
TJMike is an unknown quantity at this point
I have seen several threads on speedometer issues. This case is a 2000 Honda Civic 4 door, with auto transmission. The speedometer goes up to 20 as soon as the car is turned on in park. It doesn't change, maybe flutters a bit and that is it.
Is there a way to test the vehicle speed sensor or the speedometer?
I know it has to be one of these or the wiring between. Any quick ways to rule one out over the other without spending a lot of money?
No Check Engine light and the odometer doesn't work either.
Thanks,
Mike
Old Jul 13, 2010
Re: 2000 Civic Spedometer goes to 20mph when car is on
sounds more like the gauge cluster is bad. try to find a cheap replacement to swap in and see if it fixes the problem.
Old Jul 13, 2010
lazlong's Avatar
www.car/part.com
Old Nov 16, 2012
dwallace's Avatar
dwallace is an unknown quantity at this point
I have the same problem ( exactly ) .. were you able to find the issue
Old Nov 18, 2012
04 Honda Civic's Avatar
Use a scan tool.
rcolosi
Apr 29, 2015 07:48 PM
tattedlariat
Apr 12, 2015 07:55 PM
silvervtec01
Nov 4, 2001 06:56 PM
raitchison
Oct 9, 2001 08:22 PM
raitchison
Oct 9, 2001 08:20 PM
