1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1992 Civic Hatch won't start....sometimes
Old Jul 8, 2010
tbuelna's Avatar
tbuelna is an unknown quantity at this point
I have a 92 Civic that starts and drives perfect. Every once in a while when I go to turn it over it just keeps turning over and over and over. It's like it isn't getting gas or spark or something. I keep pumping it sometimes it fires up and sometimes I have to get a couple guys to push so we can pop the clutch. Then the car is fine again. Anyone have any suggestions or experienced similar problems? Not sure if it needs cap, rotor and all that jazz. Or perhaps a fuel filter. I am just puzzled as to why it only does it on occasion. Thanks.
Old Jul 8, 2010
annamoore's Avatar
annamoore is an unknown quantity at this point
Re: 1992 Civic Hatch won't start....sometimes
i have a 91 civic station wagon w/ the hatchback, that did that aswell for a wile. i put some fuel . it was Pro-Gard/12 oz. fuel injector cleaner. it seemed to fix it becouse my car dont do it anymore.
Old Jul 9, 2010
keithjr21's Avatar
keithjr21 is an unknown quantity at this point
check ur main relay switch cuz that just happened 2 mine n now its fixed but if u really wanna make sure it is take a piece of wire n stick it in the 5n7 slots n jump the relay 2 make sure that that is ur problem
Old Jul 26, 2010
mykissman's Avatar
mykissman is an unknown quantity at this point
mine did that...frustrating and the regular mechanics all wanted me to buy new fuel pump or distributer...turned out it was a bad heat sensor.
Old Jul 31, 2010
slty_wtrs's Avatar
slty_wtrs is an unknown quantity at this point
sounds like what mine was doing a while ago. My problem was the ignition. I changed my plugs, wires, cap and rotor (along with the msd external coil just for fun) and havent had that problem ever again. But before you do all that, spray some wd40 on both ends of your plug wires for a better connection. Its a great temporary fix.
Old Aug 4, 2010
Bengali's Avatar
Bengali is an unknown quantity at this point
Mine just recently began doing this too.
What is the main relay and where's it located?
Old Oct 20, 2010
Blondie40's Avatar
Blondie40 is an unknown quantity at this point
Mine has same 'not starting' issue, more not than starting right now. Has anyone heard of the issue being in the ignition switch?
Have changed out distributor, distributer cap, fuel pump and the main relay. When it doesn't start, the fuel pump won't pump, can't get it out of park-brake isn't allowing and the check engine light doesn't go off. When it gets started it runs great!
Old Oct 20, 2010
02civicsi02's Avatar
Low and slow!
If your ignition switch was bad then you wouldnt be even able to turn your car on. It wouldnt even turn the radio or anything on. Sounds kinda like fuel pressure problems to me.
Old Nov 19, 2010
Mafioso's Avatar
Mafioso is an unknown quantity at this point
Sounds like the Coil maybe going out, replace that along with the ignitor. They tend to go out around the same time
Rinzlor
Apr 24, 2015 10:33 AM
chirp the 1-2
Apr 19, 2015 02:19 PM
NROD315
Apr 16, 2015 08:40 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
